lower on one side, pulls to that side while driving, after aal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DSMissed, May 12, 2010.
  1. May 12, 2010 at 6:53 AM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    After doing the toytec tsb aal, I have now noticed that my truck pulls to the right while driving, and the bed of the truck is an inch slanted to the right ( passenger side). I installed both aal's facing the right direction, also made sure all tires are properly inflated. Any one have ideas of what I could have done wrong?
  2. May 12, 2010 at 6:56 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Your alignment is off. Same principle as the TSB alignment.
  3. May 12, 2010 at 7:23 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Ah, should have known. Thank you.
  4. May 12, 2010 at 7:36 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Is it the driver's side that is leaning? Because that is very common with our trucks.
  5. May 12, 2010 at 8:10 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    No it is the passenger side leaning, and it is just the box because if I stand behing the truck I can see the box is crooked compared to the cab.
    I am at the alignment shop now and he is trying to tell me that the rear isn't alignable. Wtf?
  6. May 12, 2010 at 8:17 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I didn't think you could align the rear. . .
  7. May 12, 2010 at 8:25 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    If it is not alignable, why does the dealership do it for the leaf spring tsb? I'm really confused.. there is no way this is not fixable...
  8. May 12, 2010 at 8:30 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I'm not familiar with any alignment done to the rear. I don't know what he is talking about when he says "tsb alignment". Maby they sent you two different AAL's?
  9. May 12, 2010 at 8:33 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Um, ok well I guess I'm at the alignment shop paying for a 4 wheel alignment for nothing? if alignment is not adjustable, how is this supposed to get fixed? Did I mess something up during install?
  10. May 12, 2010 at 8:34 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    second, googleing "rear wheel alignment"
  11. May 12, 2010 at 8:38 AM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    "A front end alignment, or four wheel alignment as it is commonly referred to these days due to the fact that the rear end of the vehicle can also be adjusted, does just what the name implies align, or line up the direction of the wheels so the vehicle is pointed in a straight line."
    -trustmymechanic.com
    hmmmmm. never knew that. But still I wouldn't think it would make the height of your bed change.
  12. May 12, 2010 at 9:12 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
  13. May 12, 2010 at 9:13 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    If.its still messed up when they are done I will take some.
  14. May 12, 2010 at 9:15 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    i bet its the same as my truck, it pulls to what ever way the road is slanted, usually if your on the right side of the road its going to be slanted down to the right.
    rear alignment is not adjustable on our trucks.
  15. May 12, 2010 at 9:55 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Well they just got it done, and I asked them if they fixed it, and they said yeah. I asked them how they aligned the rear, and they said, "same as the front", so thats telling me that somehow, it is alignable. Don't ask me how though.
    I dunno, but the tracking problem is fixed. The bed still leans, but I'm going to blame that on one leaf settling faster than the other... hopefully that fixes itself.
  16. May 12, 2010 at 10:10 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Can you take some pics? I installed Toytec TSB AAL as well and there was no lean to the right (passenger) side. As the previous poster said, you might have gotten a wrong leaf. The rear axle doesn't have alignment adjustments, but I did notice that when I unbolted the u-bolts I was able to move the axle forwards and backwards slightly and I had to take care to make sure that the pin that holds the leaf springs together went into about the same spot as the recess in the axle. My pin didn't actually fit into the axle because I installed axle shims. I would think that having this set incorrectly would let the rear axle be pointed off center.
  17. May 12, 2010 at 11:09 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I will get a picture. I don't know how they fixed it, they had my truck about an hour and a half. When I checked the leaf springs from toytec they were both the same size.
  18. May 12, 2010 at 11:29 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i hate that! no, it's not just like the fronts.. maybe one side of the rears, was not perfectly sitting on the centering pin. who knows?
  19. May 12, 2010 at 12:48 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    You are correct.
    The rear is NOT adjustable.
    OP should of asked him WHAT he adjusted?
    Because there is nothing he can adjust, nothing.
    It's a straight axle with a leaf pack and a shock attached to it.
    I'm glad they got the alignment fixed for you, but, something sounds weird.
  20. May 12, 2010 at 1:00 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    X10, our trucks have solid axle rear= no adjustment.
