Lower ride vs. higher ride
Discussion in '1st Gen. Tacomas (1995-2004)' started by wayerscreech, Aug 7, 2012.
  1. Aug 7, 2012 at 6:23 PM
    wayerscreech
    wayerscreech [OP] Member
    2000 tacoma sr5
    Ive seen some taco's around here lower then most that have a wider tire. It looks aggressive and i like it. What are some pros and cons of having this as apposed to having a bigger tire and lift? At this point in time I am a fan of the Stock lift but how do I get a wider tire?
  2. Aug 7, 2012 at 7:21 PM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    IIRC you can run 260/75/16 stock (as opposed to 260/70/16 largest standard stock size.) Could be wrong, it's off the top of my head.
    After that you'd need to fiddle with wheel offset or wheel spacers (and perhaps wider wheels while getting some wheel offset) to run wider tires. I believe offset is better than spacers.
    Unless you are sinking in to the sand, your wider tires are going to cost you at the gas pump and not do much else for you, IMHO. While I'm currently running not so large tires, I think your best looks with best run-ability come from the largest diameter tires that fit in the wheel wells at stock height, rather than lots of lift, but clearly that's a minority view here.
  3. Aug 7, 2012 at 7:27 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Wider tires really don't do much for you besides drain gas mileage, ask me how my 7 MPG truck does on the HWY :D
  4. Aug 8, 2012 at 10:27 AM
    wayerscreech
    2000 tacoma sr5
    What would you suggest for a more aggressive look without the killing of gas mileage
  5. Aug 8, 2012 at 10:29 AM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Put some wheel spacers on to make the stance wider.
  6. Aug 8, 2012 at 2:10 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    agreed
  7. Aug 9, 2012 at 5:03 PM
    wayerscreech
    2000 tacoma sr5
    well i heard that wheel spacers were bad for the car. i forgot why the guy said but yea.
  8. Aug 9, 2012 at 5:08 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I think it puts more stress on your lug studs, but I have not seen any fail yet....might be safer for 6+ lug studs. I was always told to stay away from them, so I do plus I'm not all into the wider stance look really.
  9. Aug 9, 2012 at 5:11 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I would only worry about spacers not being able to hold up if you are offroading. ive beat the hell out of my truck with spacers on it and havent had an issue. that being said if you put wheel spacers on you will push out your turning geometry and at full stop you run a chance of rubbing your fenders so be mindful of large spacers with out a lift. you can also trim your wheel wells if it is barely rubbing
  10. Aug 10, 2012 at 4:55 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    They arent. They put the same amount of stress on the system as equally backspaced wheels would. You would not have a problem, I beat the shit out the truck, hell my rear axle housing bent before the spacers broke.
  11. Aug 10, 2012 at 8:22 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    wheel spacers are only bad if you don't maintain the torque on them...
    going with a wider tire will lead to quite a bit of rub on stock suspension
  12. Aug 11, 2012 at 2:16 AM
    wayerscreech
    2000 tacoma sr5
    so would yall recommend getting a small lift and wheel spacers? would that prevent the rubbing issue?
  13. Aug 11, 2012 at 1:34 PM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    The low and wide stance isn't as practical unless you do a lot of mods to get there. The high and wide go hand in hand since you are putting the COG higher. It looks more proportional to go wider when going up, too, IMO. That's the look I went for with my truck!
  14. Aug 11, 2012 at 1:37 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Wide tires sucks for mpg. Thats all i have to say about that.
  15. Aug 11, 2012 at 2:40 PM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, nc
    01 Tacoma Pre-runner
    Bilstein 5100's and OME 882's in the front AAL and Bilstein 5125's in the rear Converted to 4x4, with 97 front diff with manual hubs 4.56 Yukons front and rear Custom front bumper, sliders and under-belly skid by MOBS Fab in Concord,NC with built in hella's and 8000lb smitty
    I get 17.5-18.5 mpg around town with my 33x12.50's and 4.56 gears? I didn't think that was too bad.
  16. Aug 11, 2012 at 11:35 PM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    shit we get your opinion....in every single thread...lay off it already
  17. Aug 12, 2012 at 6:34 AM
    wayerscreech
    2000 tacoma sr5
    Well the thing is I like the height that my taco is at right now. I was thinking about just getting a more aggressive looking tire and going from there. So would you all suggest a tire that is aggressive and not cost my my arm,leg,kidney, and first born?
  18. Aug 12, 2012 at 11:12 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Cooper STT, BFG KM2, Toyo MT, GY M/Tr
  19. Aug 12, 2012 at 12:32 PM
    mmcmahan2206
    McCall, Idaho
    X2
  20. Aug 12, 2012 at 12:47 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Cooper STT FTW. Love those tires
