Lower Shock Bolt
Discussion in 'Suspension' started by Kenny650, Aug 5, 2009.
  1. Aug 5, 2009 at 5:32 PM
    Kenny650
    Kenny650 [OP] Well-Known Member
    Ok. I am in the process of replacing my rear shocks but can't get the lower bolt on the shock to come off!? :confused: I have dried WD-40..etc. and it still won't budge. Any suggestions?
  2. Aug 5, 2009 at 5:33 PM
    Coastie Joe
    Coastie Joe Well-Known Member
    Andy
    NM
    16 TRD Off Road
    Torch and a hammer... Insert new bolt and WALLA! :D
  3. Aug 5, 2009 at 5:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Is the nut off?
  4. Aug 5, 2009 at 5:44 PM
    Kenny650
    I am trying to get the nut off first with a 1/2 wrench and holding the bolt with a 17mm wrench but it still wont budge.
  5. Aug 5, 2009 at 5:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Soak it with some PB blater, and let it sit overnight.
  6. Aug 5, 2009 at 6:17 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    PB Blaster or Liquid Wrench
    Spray it on the nut and the bolt and let it sit. I also tap on the nut and bolt with my wrench to help 'encourage' the solution to travel down the threads. Sometimes it helps to tighten it until it budges / breaks loose.
  7. Aug 5, 2009 at 8:05 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    sorry to jack the thread but i'm having the same problem with the upper bolt on the rear shock, every time i turn it the shaft turns with it....what do i do :confused:
  8. Aug 5, 2009 at 8:06 PM
    Kenny650
  9. Aug 5, 2009 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The center of the shock shaft is sized for a 6mm hex wrench. Insert the hex wrench into the shaft, and it will hold the shaft still.
  10. Aug 5, 2009 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Aug 5, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OR, it may have a top that accepts a wrench
    Just hold the top with the propper wrench, and turn the nut.
  12. Aug 5, 2009 at 8:20 PM
    Ese Loco
    wow.....i feel retarded haha
  13. Aug 5, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Everyone learns sometime. :)
  14. Aug 5, 2009 at 8:41 PM
    Ese Loco
    live and learn, thank you so much, we were doin the whole suspension today and had a hell of a time tryin to get the coilovers out and by the time we got to the rear shocks and couldnt figure it out, well i was so frustrated i could punt an infant across the room haha and now you tell me this i feel so much better.
    thanks to you i can now sleep tonight haha :D
    (infant comment = dane cook reference, so don't freak haha)
  15. Aug 5, 2009 at 10:41 PM
    Kenny650
    Do you know the proper wrench for the top? Can I just use vice grips?
  16. Aug 6, 2009 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont use Vice grips....I cant remember the size....I think its a 6mm also..
  17. Aug 6, 2009 at 4:17 PM
    Kenny650
    Ok I messed up. Before I even read chriss last post I went ahead and just used some channel locks. Now I can't even fit a wrench in there because there isn't much to grip on the top anymore....
  18. Aug 6, 2009 at 4:33 PM
    jandrews
    '09 FourDubDee TRD OR
    Stuff like this is why he's the best Chris4x4 on the whole site.
  19. Aug 6, 2009 at 4:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Aug 6, 2009 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lol!! :d
