lower strut bolt seized
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bulhas, Jan 8, 2013.
  1. Jan 8, 2013 at 4:37 PM
    bulhas
    bulhas [OP] the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    well trying to take my lower strut bolt out, ive run into an issue......
    its seized in the bearing..... the bolt spins but spacers and inner bearing does too.....
    i think im going to get a bigger bfh and kroil the shit out of it tonight .....
    any other tips would be great
  2. Jan 8, 2013 at 5:26 PM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Pb blaster then use air.
    Not a good application for a hammer or heat
  3. Jan 8, 2013 at 8:16 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You talking about the bolt that holds the shock to the LCA? Seized in the bushing? Did you try an impact from the head of the bolt and see if it'll back out at all?
    If not, lots of PB or kroil, let it sit, and then a long punch and a hammer, and if that doesn't work wail on it with a air gun.
    Use antisieze all over the bolt when you put it back in. :D
  4. Jan 8, 2013 at 8:25 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Yup gonna say the pb man good shit... What u fixin/improving?
  5. Oct 25, 2013 at 4:13 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I'm having this issue and have tried all of these suggestions. Can anyone else help me out?
  6. Oct 25, 2013 at 4:17 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Breaker bar?
    If its really siezed your going to have to take it off the truck to get the kind of acces you need to do it yourself or take it to a machine shop to get it drilled out.
    It shouldn't be that hard to get with regular tools.
    I don't really understand what is spinning however. Can't you just put a wrench on it to stop the spinning?
  7. Oct 25, 2013 at 4:20 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    how can it spin when you have a wrench on the bolt head?
  8. Oct 25, 2013 at 4:29 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    There is a metal sleeve that sits in the lower strut hole. The bolt that runs through that sleeve has seized to the sleeve. The bolt and sleeve turn, but it won't release from the sleeve.
  9. Oct 25, 2013 at 4:29 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    This is correct.
  10. Sep 1, 2020 at 12:51 PM
    CO_T4R
    CO_T4R New Member
    @bulhas Old thread, I know. I'm having the exact same issue. How did you end up getting the bolt out?
    Thanks!
  11. Sep 1, 2020 at 2:35 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had this happen years ago. I had to get a Dremel with some small cut-off wheels and cut the bolt, both ends, just outside of the tabs that hold it. Then, slightly bend the tabs out and pry the bottom end of the strut out.
    It's a pain in the ass but the only way I could think of to get it out.
    Any hand held grinder that's bigger can be tough to get into the tight spots.
  12. Sep 1, 2020 at 2:47 PM
    CO_T4R
    CO_T4R New Member
    Thanks @winkel . I called Toytec today, and that is precisely what they recommended. Another option they mentioned was to cut off the very bottom of the shock. I'd love to save the bold, since the replacement Alumas don't come with new bolts. It's soaking right now, and I'll put the ball joint press on it tonight to see if I can press it out. Otherwise, I'll do exactly what you did. Will report back.
  13. Sep 1, 2020 at 4:32 PM
    winkel
    Corydon, IN
    Some people recommend anti seize when you reinstall the hardware. This is good advice. I always just use a little grease. It'll work well too.
  14. Sep 1, 2020 at 4:58 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Sawzall and diablo blades. Then have fun.
  15. Sep 1, 2020 at 5:42 PM
    winkel
    Corydon, IN
    If I recall correctly, I didn't have room to get a sawzall in there. Not sure on the exact application here but yes, the principle would still be the same.
