Lower strut bolt wont come out !?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sander1036, Aug 6, 2011.
  1. Aug 6, 2011 at 1:18 PM
    sander1036
    sander1036 [OP] Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    So im in the process of my toytec ultimate lift and i have taken my original drivers side coilover off and am on to the passanger side and the bolt holding the bottom of the coilover will not come off.. Any advice would be awesome
    :confused:
  2. Aug 6, 2011 at 1:21 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    what do you mean by wont come off is the nut already off and it wont slide out?
  3. Aug 6, 2011 at 1:23 PM
    sander1036
    Exactly the nuts off it just wont slide out ive beat on it but its not budging
  4. Aug 6, 2011 at 1:24 PM
    johnw
    john
    orlando florida
    put the nut back on till it is even with the end of the bolt and hit it with a hammer see it that work. this is just so you dont mess up the threads
  5. Aug 6, 2011 at 1:26 PM
    sander1036
    i was using a block of wood and a heavy hammer and it wasnt doing anything
  6. Aug 6, 2011 at 1:28 PM
    johnw
    john
    orlando florida
    hmm maybe spray some pb blaster on it and start wiggling the coil back and forth to maybe break it loose?
  7. Aug 6, 2011 at 1:31 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    ^^this
  8. Aug 6, 2011 at 1:31 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    put your socket on the bolt and turn it while your hitting out
  9. Aug 6, 2011 at 1:32 PM
    sander1036
    ill try wiggling the hell out of it but ive got it blasted with wd 40 and it just doesnt want to budge
  10. Aug 6, 2011 at 1:33 PM
    johnw
    john
    orlando florida
    x2
  11. Aug 6, 2011 at 1:33 PM
    sander1036
    cant get a socket in there too much stuff in the way
  12. Aug 6, 2011 at 1:34 PM
    sander1036
    ill go try some stuff thanks for the help guys ill be back on then if it doesnt work
  13. Aug 6, 2011 at 1:34 PM
    Bfoster133
    Blake
    move stuff :D haha jk post a picture of what exactly is goin on
  14. Aug 6, 2011 at 1:35 PM
    MTgirl
    Weesa
    wipe any excess wd40 etc from the area and hit it with a blow torch very briefly...the heat may help break things loose
    have you tried compressing the spring a little more as you work the bolt out? if the spring is straining the bolt laterally it could be working against you.
  15. Aug 6, 2011 at 1:36 PM
    sander1036
    will do then dont have internet in my barn but ill get some pics up to show you guys then
  16. Aug 6, 2011 at 2:29 PM
    sander1036
    thats what i got i cant get to budge i tried compressing the spring didnt work tried prying the a arm down didnt work its wedged in there good.. im starting to throw things :frusty:
  17. Aug 6, 2011 at 2:36 PM
    wtmtntaco
    wtmtntaco Well-Known Member
    NH
    03 TRD xtracab V6
    Bilstein 5100's at 2.5", Grey wire, Wheeler's 1.5 aal,
    pb blaster is your friend, soak it good, put the nut back on the end and hit it good, trying to unweight the shock helps too
  18. Aug 6, 2011 at 2:38 PM
    MTgirl
    Weesa
    BFH?
    hacksaw?
    :notsure:
  19. Aug 6, 2011 at 2:40 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    take something like a 2x4 and push up or down on the upper controll arm the strut may still have a lot of preasure on the bolt and that may help.
  20. Aug 6, 2011 at 2:41 PM
    sander1036
    ill try to find some, and i took all of the weight off of the shock
