Lower T Case Gearing for my 2020 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitelandcruiser, Jan 8, 2024.
  1. Jan 8, 2024 at 7:39 PM
    whitelandcruiser
    whitelandcruiser [OP] Member
    Frank
    2920 trd
    None yet
    I don't see alot of options for dual cases for 6 speed manual 3rd gen Tacomas...Besides going to FJ Cruiser T case our an Atlas what other options are out there?? I have run Atlas before but just seems big time over kill for a little tacoma...
  2. Jan 8, 2024 at 7:48 PM
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    Crom likes this.
  3. Jan 8, 2024 at 7:53 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You could get a Northwest Fab eco crawler box which is essentially a doubler and gives you an additional 2.57:1. A benefit to that is being able to engage it while leaving the transfer case alone for an instant 2LO.
    As expected, it isn’t quite a simple bolt in. You need some planetary parts from an existing transfer case to install into the crawler, as well as need to lengthen the front and shorten the rear driveshafts, in addition to enlarging the floor hole for the shifter and extending the transfer case wiring since the tcase gets relocated rearward by about 6”.
    I don’t know of really any other good options for lower tcase gearing. Atlas is a given, most of the Toyota cases are around 2.57:1 so a doubler probably makes more sense.
  4. Jan 8, 2024 at 7:53 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
  5. Jan 8, 2024 at 8:03 PM
    whitelandcruiser
    Frank
    2920 trd
    None yet
    Yes I did read up on their case setup.They need a donor t case up front..Which is not hard but 6 speed manual t cases are not that easy to find..This seems to be the best option yet cost is close to an atlas by the time you are done..
  6. Jan 8, 2024 at 8:46 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I went with the Marlin product. All Pro Off Road had a similar one as well, although I can't seem to find it on their website at the moment. Haven't yet installed my 4.7 gear unit.
