Lowered 2002 - how do I improve traction?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ulose2a6, Dec 22, 2022.
  1. Dec 22, 2022 at 10:15 AM
    Ulose2a6
    Ulose2a6 [OP] Member
    2002 Tacoma 2JZ
    Supra swapped 2JZ with single turbo. R154 gearbox Ford 8.8 rearend Lowered
    Hello Folks,
    I have a lowered 2002 and would like to get ideas on improving the traction and ride. Lowered with Eibach lowering springs up front and blocks out back with the stock leaf springs. Bilistein shocks up front and air shocks in the rear. Truck spins and wheel hops when launching hard.
    I spoke with CalTracs and the truck is too low for them to work.
    Hopefully others out there have tried different things and have some success.
  2. Dec 22, 2022 at 11:15 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It all comes down to what your end game is.
    We are more lifted trucks and bigger tires. I never heard Launch on this forum before.
    You need more weight being transferred to your rear axle! something like 90 /10`s upfront
    What kind of tires wrinkle wall slicks tire pressure would need to adjusted to a comprise.
    Is this truck street legal? A truck setup for a straight line sucks to drive on the street.
    It has been many years since my Drag racing days .
    Those Air shocks might be making things worse. Custom made traction bars .
    As Drag cars seldom had frames.
    I really hope this is not a 4x4
    Have you checked out street truck forums
  3. Dec 22, 2022 at 4:10 PM
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    The blocks are why you have axle wrap. You should look into drop leafs to help with the ride and wrap.
    Pabloeeto, Ulose2a6[OP] and Bivouac like this.
  4. Dec 22, 2022 at 7:50 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You have axle/spring wrap. The blocks make the problem worse. You should look into building a traction bar if you want to keep the leaf springs.
    Ulose2a6[OP] likes this.
  5. Dec 22, 2022 at 9:10 PM
    Ulose2a6
    2002 Tacoma 2JZ
    Thanks so much for the replies. All very helpful. I agree I think the blocks gotta go. Anybody know who sells the lowering leafs?
  6. Dec 23, 2022 at 1:32 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Linked ford 8.8 rear :eek:
  7. Dec 23, 2022 at 4:30 AM
    Ulose2a6
    2002 Tacoma 2JZ
    I don’t understand Sebz
  8. Dec 23, 2022 at 4:41 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Spring under solves a lot of axle wrap issues.
    tinker_troy and Ulose2a6[OP] like this.
  9. Dec 23, 2022 at 7:09 AM
    Ulose2a6
    2002 Tacoma 2JZ
    Any suggestions on where to source those types of leaf springs from rnish?
  10. Dec 24, 2022 at 9:53 AM
    mtb_taco
    2001 Tacoma
    Look up S-dad mod. For you truck you'll need a pair of 98-04 4x4 leafs and will get about 3" drop and handle and ride great. I've done it and still have this setup on my 01 and love it.
    Ulose2a6[QUOTED][OP] likes this.
  11. Dec 24, 2022 at 12:02 PM
    Ulose2a6
    2002 Tacoma 2JZ
    Thank you Mtb_taco. I will definitely. That’s great information. I appreciate it.any pics of your truck lowered with them?
  12. Dec 24, 2022 at 12:29 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    You don't have much weight in the back. What size tires are you using? And if you're open diff then you're going to be hopping all kinds of wheels, buy an LSD.
  13. Dec 24, 2022 at 1:10 PM
    Bivouac
    By lots of spare differentials with the gears you need.
    Weld them up replace as they explode !
    That was the hot set up when you could not afford a spool in my youth.
    Nano909[QUOTED] likes this.
  14. Dec 24, 2022 at 1:15 PM
    Nano909
    Xcab 3.4 4wd 5MT
    We still do that, but only with vehicles we don't care about. Hahaha
    Bivouac[QUOTED] likes this.
  15. Dec 24, 2022 at 1:21 PM
    Bivouac
    Ha ha Ha!! early seventies .
    Then Chevy open differentials could be had at any yard .
    I bet there was 25 within a 30 mile radius .
  16. Dec 24, 2022 at 1:39 PM
    Nano909
    Xcab 3.4 4wd 5MT
    That must be nice. Around here, a rear diff for any Toyota truck won't last 2 minutes in the junkyard.
  17. Dec 24, 2022 at 1:57 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Try weight jacking with your air shocks. Preloading the right rear can do wonders. My drag car liked 50 psi in the rr and 5 psi on the left. The rear axle twists with the drive shaft (adds load to the right side) preloading helps that a lot. Coil spring cars got a station wagon spring or special wound heavy coil in the right. Sixties muscle cars with leafs often had a lot stiffer right rear - like an extra leaf in the mopar cars. My 442 liked soft "cheater slicks" - check Hoosier tire for some DOT legal softies
  18. Dec 24, 2022 at 8:18 PM
    Ulose2a6
    2002 Tacoma 2JZ
    Thanks will give it a try for sure easy enough.
  19. Dec 24, 2022 at 8:21 PM
    Ulose2a6
    2002 Tacoma 2JZ
    It’s 285/40-18’s in the rear. Was trying to get Nitto 555 R2’s but they are back order for months so went with their 555 G2’s. It’s a Ford 8.8 posi rearend. I might get some cement bags and put back there too.
  20. Dec 24, 2022 at 10:51 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Aw man, you should have tried out the NT05. They're hella grippy.
    With removing the blocks and adding a bit of weight in the back, I think you'll be good.
