Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Jan 21, 2014 at 9:58 AM
    #1981
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Hmmmm I am at 9 on drivers and 6 or 7 on passenger. New seats have made it more plush
  2. Jan 21, 2014 at 10:00 AM
    #1982
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    why are you on different setting? Taco lean?
  3. Jan 21, 2014 at 10:00 AM
    #1983
    Phil Dammit
    Your Mom
    Tempe, Arizona
    yeah and to compensate for the added weight of driver.
  4. Jan 21, 2014 at 11:02 AM
    #1984
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    I actually know a guy who cracked his frame on his X with DJM bolt on but it was because the guy who cut it cut a half circle with a triangle at the top instead of the trapezoid shape that it's suppose to be and the notch wasn't bolted on tight and this guy carries plenty of things in the bed but as for mines it's all g I cut my on point but I want a taller notch and to box it since the jdm one is so shallow
  5. Jan 21, 2014 at 11:16 AM
    #1985
    Phil Dammit
    Your Mom
    Tempe, Arizona
    How shallow is that notch, Mines about 2" maybe a little more
  6. Jan 21, 2014 at 12:29 PM
    #1986
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I'm not sure I just hate how the design is the driver side is a large notch and the passenger side is smaller however with offset pics where the notch is suppose to go I am like at the edge on the driver side and centered in the passenger just overal dumb design
  7. Jan 21, 2014 at 12:35 PM
    #1987
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What?!?!?:confused:
  8. Jan 21, 2014 at 8:16 PM
    #1988
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Bro exactly what my thoughts were like I said just overal I am not a fan if the design but came with the kit and I hated riding bumpstops so did what I had to do
    I didn't cut the part out for the bumpstops to thread through though just in case I re notched which I prolly will and I wanna fix my camber just got it aligned today maxed out -2.0 which means it got worse since when I first did the drop and it's prolly do to my bent plate for my alignment bolt.... Fml got things I wanna do no time to do it and I gotta drive the bitch daily
  9. Jan 21, 2014 at 8:26 PM
    #1989
    Kavik
    Kavik Kavik
    Texas, DFW
    Big reason why I haven't notched is because mine is a daily driver, can't afforded to have my truck out if action if a problem does arise.
  10. Jan 21, 2014 at 9:27 PM
    #1990
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I know the scares of notching but the bolt on kit is fine I just bitch about it cuz me want more low but I've reached my notched limit
    The reason for failure is poor installation really
    Weld in notches I'd say are better as long taps the notch isn't shaped like a -^- like this you should be fine sharp edges is what causes crack which is why they say round the edges when cutting the notch
  11. Jan 21, 2014 at 10:42 PM
    #1991
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yeah you hahah I not artsy but you got the point
  12. Jan 22, 2014 at 5:51 AM
    #1992
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I'm notched, dailied, and more lowz then you ;)
    Here, listen to the chorus, will make you feels better daddy.
    http://youtu.be/Gk7CDFEDD-g
    And -2 aint bad for how lowerdzed you are. I'm at 1.7 neg niqqa
    Doesn help that you are slammed like a mothafucka
    mine is like Seth's texted interpretation, cuts are square but I also boxed and full pen welded it.
    LMAO
  13. Jan 22, 2014 at 9:41 AM
    #1993
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Gahh but I like be more low without cutting the bed open:(
  14. Jan 22, 2014 at 10:34 AM
    #1994
    Kavik
    Kavik Kavik
    Texas, DFW
    Anybody have the front coilovers yet?
  15. Jan 22, 2014 at 10:45 AM
    #1995
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Nope, they are actually heading over to see the machinist in the next couple days. Think they are just waiting on the top hats before they are sent out. I'm about to pee my pants with anticipation of receiving them in the mail.
  16. Jan 22, 2014 at 11:19 AM
    #1996
    Kavik
    Kavik Kavik
    Texas, DFW
    Guess I will have to save my pennies but $950 could buy a lot of stuff I need for the Datsun.
  17. Jan 22, 2014 at 11:19 AM
    #1997
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I only spent 850, that extra hundo bought my seats:cool:
  18. Jan 22, 2014 at 1:07 PM
    #1998
    Phil Dammit
    Your Mom
    Tempe, Arizona
    :rolleyes:
    Woaw woaw woaw, how much you gonna end up spending when we are all said and done with?
  19. Jan 22, 2014 at 1:17 PM
    #1999
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Agreed!
  20. Jan 22, 2014 at 9:02 PM
    #2000
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    That turbo doe!!! That white one prolly could of did better if he wasn't going down the middle of the track haha he was all over the place need a better burnout for better traction but anyhow dayum!!!!!!!!
