Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Apr 4, 2014 at 1:41 PM
    #2421
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Eh thanks for suggesting junk shop pros! They gonna be the cheapest! You da man. Traded qa1's for 1 and a Half tires ha ha
  2. Apr 4, 2014 at 2:39 PM
    #2422
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Haha yup they got good prices I know a guy there that works the body shop side he has the 7/8 drop boosted 1st gen taco
  3. Apr 4, 2014 at 3:20 PM
    #2423
    jmarquez808
    Jess
    Hawaii
    Dayummm!!!
  4. Apr 10, 2014 at 8:47 AM
    #2424
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
  5. Apr 10, 2014 at 10:40 AM
    #2425
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    FML
    This is gonna take some time to wire up.
  6. Apr 10, 2014 at 12:12 PM
    #2426
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What you throwin mega squirt on?
  7. Apr 10, 2014 at 12:16 PM
    #2427
    Kavik
    Kavik Kavik
    Texas, DFW
    The 260z.
  8. Apr 10, 2014 at 12:43 PM
    #2428
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Squirtin the rust bucket eh? Should be fun, last 240 I worked on the MAF took a shit for the fuel pump turn on and someone had hacked the harness so no ignition turn-on for the starter. Ended up hard wiring the pump to the acc relay on the ignition side, wired in a push start that I put in the cig lighter outlet, and wired back in the main harness relays. On top of numerous motor issues I fixed, also cleaned up the interior. Then the chick that owned it dumped me like a bad habit, right before I was getting ready to start her coilovers.
  9. Apr 10, 2014 at 3:49 PM
    #2429
    Kavik
    Kavik Kavik
    Texas, DFW
    Trying to at least, I am gonna see if painless performance can make a full wire harness for the Z so it will be easier to work with.
    The intercooler setup is almost finished but I need a 3 inch to 2.5in 90 degree elbow with at least a 3 1/2 leg and of course the only place that seems to carry them (HKS) also sells them for $50 plus another $15 for shipping for just one! Race car problems.
  10. Apr 10, 2014 at 4:19 PM
    #2430
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What motor are you running? Where is the build thread?
  11. Apr 10, 2014 at 4:23 PM
    #2431
    Kavik
    Kavik Kavik
    Texas, DFW
    Search project slide to unlock. It was originally singlecabguy's build thread but I took it over after I bought it from him.
  12. Apr 10, 2014 at 4:23 PM
    #2432
    Phil Dammit
    Your Mom
    Tempe, Arizona
    LMAO, werd.
  13. Apr 12, 2014 at 6:42 AM
    #2433
    Upnover
    Upnover Active Member
    Togie
    North Carolina via Ewa Beach HI.
    07 Regular Cab
    Same as most but nothing compared to some.
    need more lowered... anyone selling DJM kit for sale ?
  14. Apr 12, 2014 at 10:28 AM
    #2434
    jmarquez808
    Jess
    Hawaii
    I would buy new
  15. Apr 12, 2014 at 11:03 AM
    #2435
    Upnover
    Togie
    07 Regular Cab
    good to know thanks
  16. Apr 12, 2014 at 3:47 PM
    #2436
    jmarquez808
    Jess
    Hawaii
    *****! what can you do lol
  17. Apr 16, 2014 at 8:29 AM
    #2437
    Upnover
    Togie
    07 Regular Cab
    got some questions , Dammit answered most but he probably tired of getting p'd
    as it sits I have Xii coils w/Billy's and 1" spindle spacers upfront rear is 3" blocks
    parts in a brown truck or maybe white
    3" DJM arms and blocks, Qa1's
    parts I'm picking up
    4wd leafs
    notch on welding table in AZ
    should I add the new chit to what I have(no I'm not block stacking)other than the notch , what other fab work may I need to do? e-brake? exhaust ? driveshaft ?
    or should I just stick with DJM arms no spindle spacers or 4x leafs ?
  18. Apr 16, 2014 at 8:34 AM
    #2438
    Phil Dammit
    Your Mom
    Tempe, Arizona
    The route you are going is right in line with what I had on my truck before coilovers. You've been through my build a couple times, but I reference most of the issues you will have to address before you slam.
    1) use a hose clamp on the shaft tunnel to attach the passenger side ebrake line to body so it does not rub on shaft.
    2) Notch bed fins in composite bed to stop the third member from hitting it
    3) Notch bed cross member directly above third to stop from slamming and crushing charcoal can
    4) Pull the leafs apart before you install, clean any dirt out, regrease leafs.
    5) 4" beefed blocks
    and I dont mind the PM's
  19. Apr 16, 2014 at 11:16 AM
    #2439
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Slammed to be!
  20. Apr 17, 2014 at 2:53 PM
    #2440
    Phil Dammit
    Your Mom
    Tempe, Arizona
    For once Kase is right, nothing major bro, tundra racing kit. Thought you knew about that Ry Ry?
