Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Dec 27, 2012 at 7:44 AM
    #481
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    I djmd my xrunner while it was still under warranty lol
  2. Dec 27, 2012 at 10:09 AM
    #482
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    Main problem with dropping a second gen a bunch is the negitive camber up front
    Also, my DJM should be going on tomorrow. Just need to get a 1/8th bit, greese gun, grinder and a t55 bit and rent a ball join puller from Advanced. Wish me luck
  3. Dec 27, 2012 at 10:46 AM
    #483
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Quite a bit more challenging, if you want to keep the parts in "bolt-on" fashion. You know. ;)
    I still need to pick up some ICON UCA's.
  4. Dec 27, 2012 at 2:53 PM
    #484
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The adjustable ICON UCA's. Since my setup is lower than the TundraRacing kit. Help correct a camber issue as well as allow me to go a tad lower without binding so badly. Your UCA's will be just fine. Might even allow you to get a tad more low depending with proper camber, if they were constructed a little longer than factory.
  5. Dec 27, 2012 at 4:36 PM
    #485
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    Why you going low? I thought you wanted to build a prerunner?
  6. Dec 27, 2012 at 4:41 PM
    #486
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I believe they will work as well
  7. Dec 27, 2012 at 6:53 PM
    #487
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Made a thread about this but thought i'd ask here, How did you guys remove the rivits that hold the stop bump stops to the frame? Trie drilling which wouldnt work for the bottom ones and a cut off wheel didnt work either. Any ideas?
    For the 05+ DJM kit
  8. Dec 28, 2012 at 11:56 AM
    #488
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    correct me if i'm wrong...
    aftermarket 6 lug UCA's generally help the suspension get into alignment by inducing NEGATIVE CAMBER to alleviate increasing POSITIVE CAMBER as you lift, correct?
    so at stock height, the UCA's should cause the some negative camber?
    so at a lowered height, where most of us are trying to reduce NEGATIVE CAMBER, you will be worsening it with the use of these aftermarket UCAs.
    or I could be talking nonsense. idk. i think i make sense, no?
  9. Dec 28, 2012 at 2:27 PM
    #489
    98_Mud_bug
    lucedale Ms.
    Once the ucas pass factory point, whether loering or lifting, you will get negative camber. If it goes up too far, it will still pull the top of the tire in.
  10. Dec 28, 2012 at 2:54 PM
    #490
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And thus my desire for the adjustable ones.
  11. Dec 28, 2012 at 4:52 PM
    #491
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    why not just keep it the way it is?? Why take a 6lug suspension truck and lower it? Especially when you already have pre runner parts
  12. Dec 28, 2012 at 10:34 PM
    #492
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Stage 2 of the mods, DJM 3" front, which really really needs and alignment and 2" rear cause i had issues with the notchFun measurments, 6" from the bottom of the engine brace and 8" from the bottom of the diff case
  13. Dec 30, 2012 at 5:11 PM
    #493
    98_Mud_bug
    lucedale Ms.
    gtr across the road? nice. truck is lookin good, but what did you do to your bedside?
  14. Dec 30, 2012 at 5:17 PM
    #494
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Nope it's my dads GTR, i had been using the garage all day to install the kit so we had to make sure it was clean of tools for it to pull in. Thanks and i had put the stockers back on but i guess wasnt used to how stockers go on and had it put on wrong so the wheel fell off and fell under the truck in a turn. on the plus side i can just replace the bedside and will end up turning the truck black, wither by wrap or plasti dip. Still need to install the 4" rear drop once i get access to a air chissle, not looking forward to trying to cut the frame with a grinder.
  15. Dec 30, 2012 at 5:25 PM
    #495
    98_Mud_bug
    lucedale Ms.
    thats how i cut mine, it was a pain in the ass. the frames on these trucks are really hard, best bet is a torch, or plasma cutter. I went through 3 cutting wheels to cut my notch out.
  16. Dec 30, 2012 at 7:18 PM
    #496
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Wish i had access to those kind of tools lol. Not looking forward to it lol. But it's gonna look cool imo which is all that matters. After 12 hours to do the Front arms it'll Seem like a cake walk. Funny thing about the front were we needed new lower ball joints and had to have them pressed in, so we were using the GTR as a Parts runner for a truck :anonymous:
  17. Dec 30, 2012 at 8:35 PM
    #497
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Yeah..... i have nothing to say to that, Thanks for your service though :oldglory:
    Also saw this at the gun show today
  18. Dec 31, 2012 at 12:38 AM
    #498
    Kelson
    Kelson
    Honolulu, Hawaii
    mean da oem alloys
  19. Dec 31, 2012 at 9:41 AM
    #499
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    I was annoyed when i saw that cause i couldnt even be the lowest toyota there
  20. Jan 1, 2013 at 1:13 PM
    #500
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Hmm, I think I might repaint my rims soon. I am thinking either all black or color matched super white.
