Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Jan 13, 2013 at 1:02 PM
    #541
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Rotrex or turbo FTW!
    After school and all. ;)
  2. Jan 13, 2013 at 1:46 PM
    #542
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is one guy on here who is building his 2TR. Curious to see how that turns out. There has been a 2JZ swapped into this body style. On a 4x4. As well as numerous LS engine swaps. Hmmmmm....decisions decisions......
  3. Jan 13, 2013 at 4:58 PM
    #543
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    What type of vehical inspections does Texas require? Because here in MO they require the OBD2 to be read which if you swap it'll read a different vehicle and VIN that what the truck shows and will fail you unless you can find someone to change all of that.
    Sorry for being a buzz kill lol.
    But the 2TR has a forged crank with some forged rods and pistons could turn into a mean sleeper and the 2.7L displacemnt would make the turbo spool faster than the most 4 cyls depending on your power level. Also remember both the 2jz and Ls motors cost about 3k for the engine and trans without install, so it'd be cheaper if you build the 2tr right than it would to buy and swap another engine most likely
  4. Jan 13, 2013 at 6:19 PM
    #544
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just the crank. Still need rods and pistons.
    If the 2TR is anything like the 2rz/3rz, it will be a beast with a turbo.
  5. Jan 13, 2013 at 6:33 PM
    #545
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Lucky SOB lol
    Just the crank like Torspd said, but i'd think it'd only be 1-1.2k for pistons and rods depending on compony. Also how are u with a welder? It would save alot of money
  6. Jan 13, 2013 at 6:39 PM
    #546
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    weird yet somehow it's still interesting
  7. Jan 13, 2013 at 6:43 PM
    #547
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    I was just curious. Sounds like you have a plan now
  8. Jan 13, 2013 at 8:17 PM
    #548
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Make me a turbo :spy: :D
  9. Jan 13, 2013 at 10:07 PM
    #549
    Kavik
    Kavik Kavik
    Texas, DFW
    I might take you up on that.:cool:
  10. Jan 16, 2013 at 5:27 PM
    #550
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    Xbars don't stop wheel hop
  11. Jan 16, 2013 at 5:34 PM
    #551
    98_Mud_bug
    lucedale Ms.
    I don't have an xbrace on mine, and can't tell a difference than when it was on there.
  12. Jan 16, 2013 at 5:36 PM
    #552
    98_Mud_bug
    lucedale Ms.
  13. Jan 16, 2013 at 6:35 PM
    #553
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Might as well get the QA1's as well.
  14. Jan 16, 2013 at 6:35 PM
    #554
    98_Mud_bug
    lucedale Ms.
    Are you on xrunderground.com yet?
  15. Jan 16, 2013 at 6:37 PM
    #555
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I was about to ask the same thing. Lol
  16. Jan 16, 2013 at 6:59 PM
    #556
    98_Mud_bug
    lucedale Ms.
    Do it, there's a lot of good suspension info on there for sure...
  17. Jan 16, 2013 at 7:12 PM
    #557
    Kavik
    Kavik Kavik
    Texas, DFW
    I will take the x-brace if you dont want it. :cool:
  18. Jan 16, 2013 at 8:52 PM
    #558
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    I would take the X-brace and put it on eBay as there are quite a few people looking for one :p
    I agree with the previous posts in that the swaybar would be useful, but I doubt you'll see any benefit from the X-brace. For one, the X-Runner is a V6 that puts out whole-lotta horsepower compared to our 4-banger Taco, so perhaps the composite bed does flex a bit due to the higher horsepower and the longer frame that the X-Runner has (because it's an extended cab). If I'm not mistaken, the mounting points for the brace don't exist on non-X-runner trucks, so you'd have to have some kind of plates welded to your frame just to have some place to bolt the brace.
    The X-Runner clone thingy has already been done... and done quite nicely I might add:
    I find it ironic that the owner of the above truck put all that work into it and then sold it to a used car dealer shortly after it was completed! :confused:
    As for the QA-1's... I know everyone raves about them. However, it sounds to me like most people who get QA-1's do so because the shocks are adjustable and people adjust the dampening to prevent bottoming-out... especially when there is a load in the bed (of which really isn't the shocks job to do that, but I digress). If you're not going to do an insane drop (< 3 inches) and have a notch, are QA-1's still worth it? I've been a pretty big fan of Bilstein shocks for quite a while and they're a heck of a lot less expensive than the QA-1's. If performance is the goal and preventing bottoming-out is not, are QA-1's still superior to Bilsteins?
  19. Jan 17, 2013 at 6:26 AM
    #559
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does Bilstein make an adjustable shock? I cannot remember.
    I know I looked and looked for some adjustable coilovers from them for the front. Couldn't find the proper one though. As much as I want to. For the rear, it would be pretty easy to find a properly sized shorter Bilstein, though. As those are plentiful.
    For me, currently, QA1's are the best bet in the rear. Simply because I know they fit, they are available, and they are adjustable. So when I start hitting the road course, I can adjust them depending on the track needs.
    KW was uninterested in helping find a proper front fitting coilover. But I am fairly positive one could find a set for the rear. AFCO is very helpful. They want to do some things done. ;)
  20. Jan 17, 2013 at 7:00 AM
    #560
    Hot Taco
    Richfield, WI
    We're pretty much limited to the X-Runner's Bilsteins for our truck. If you lower the rear of your truck using blocks, you don't need to get a shorter shock.
    I have Bilstein coilovers on my car and Bilstein shocks + struts on my Gen 1 Tacoma and am quite happy with both. (Heck, I think I actually giggled when I first drove my car after putting on the coilovers :p ).
    The rear X-Runner Bilstein shocks are only $36.47 each ($72.94 for both), so compare that to $289.99 for the QA-1s ($579.98 for both), and the QA-1's better doing something pretty darn special for 8x the price!!! Granted, you're getting adjustable dampening and a nice, chrome finish, but that's still a pretty hefty price.
    Once again, if you're trying to prevent your axle from hitting the frame, I guess the QA-1 is a really expensive solution for that. However, I'm skeptical of the notion that the QA-1 is somehow going to make a truck's rear suspension perform radically better... especially since our trucks just have crappy leaf springs in back which is hardly a performance suspension setup to begin with.
