Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. May 10, 2013 at 4:46 PM
    #981
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    I have 3 and 1/2 18s I could sell you lol
  2. May 10, 2013 at 5:34 PM
    #982
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Thanks! (I think? :p)
    Just to keep things fun around here, attached is a 'teaser' pick :D
    I kept teetering between 19's and 20's literally for months (way before I even bought my dumb-head truck). 20" tires are typically cheaper, but there's a lot of negatives to them:
    • wheels and tires weigh more
    • the weight is further from the center of the wheel, decreasing acceleration and braking performance even more (but then again, by going with 19's, it's not like I'm going to get great performance anyway)
    • I'd have to run such a small aspect ratio to keep the speedometer correct that rim protection from potholes becomes none-existant.
    I've read all sorts of posts about people running 40 series tires having bent or damaged wheels and wishing they had gone with a 45 series. I had 45 series tires on my last truck for over 10 years, so I'm assuming that's a pretty safe bet. Since my truck is a daily driver, I do need a little sidewall, so 19's won.
    Now I have to pick some tires and get them mounted. I plan on visiting Discount Tire as they're the only shop I've heard of that can install programmable TMPS sensors. The plan is to have new sensors put in the new wheels with the same sensor IDs as my OEM wheels. That way, when I swap my summer wheels for my winter wheels, the TMPS light will stay off w/o a trip to the dealer.
  3. May 10, 2013 at 7:56 PM
    #983
    black09
    black09 Well-Known Member
    chris
    elkton Maryland
    2009 black 2wd base
    4.5/ 5.5 drop color matched front bumper smoked tails frenched plate in tailgate shaved tailgate handle molded rollpan fogs suede headliner suede inserts in seats with headrests removed suede arm rest kenwood double din tv mtx 12" sub with 500 watt amp trd hood full billet grill setup
    i have a 35 series on my 20s and my speedo is correct guess i got lucky
  4. May 10, 2013 at 8:01 PM
    #984
    Hot Taco
    Richfield, WI
    If you're running a 255/35/20, then your tire's outer diameter is nearly identical to stock, so it'd make sense that your speedo is accurate. (But a 35 series tire sure is skinny!)
  5. May 10, 2013 at 10:28 PM
    #985
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    yea they look hella mean but they are rough especially whe nroads are rough also add in the fact i have almost no suspension travel che heee!!
    yeah 245/35/20 is what i have up front and os .1" smaller in diameter than stock which isnt much however 245/35 is the lowest profile id go thats why im going with 18's so i can down size the tire and still have some tire left over 19's the tires are way too expensive for me
    if you un a 245/40/19 0r 255/40/19 you should be perfect mainting the speedo and ive seen 245/40 and 255/40 they arent over sized sidewalls but they also arent rubberbands
    you dont really need 45 series unless u have no choice but to go through every pot hole naw mean i understance the concern for busting a tire but much of that can be avoided by careful driving just my 2 cnts
    19's are perfect blend of enough rim and enough tire for the 2nd gens
  6. May 11, 2013 at 11:25 AM
    #986
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    So im thinking about fixing my fender and selling the Taco to buy a turbo car
  7. May 11, 2013 at 2:55 PM
    #987
    black09
    chris
    elkton Maryland
    2009 black 2wd base
    yup thats my exact tire i didnt plan it out i just figured a 35 works the best lol it is skinny and make a ruff ride
  8. May 11, 2013 at 2:57 PM
    #988
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    lol, I remember when I was in that phase of my life :p
    All my friends had boosted cars, and I was the slow one of the group. I eventually stopped caring.
  9. May 11, 2013 at 2:59 PM
    #989
    black09
    chris
    elkton Maryland
    2009 black 2wd base
    if i could id sell mine and get a new f150 ecoboost and slam it not a car but its turbo
  10. May 11, 2013 at 3:28 PM
    #990
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    It's not even that all my friends have boosted cars, I can use the GTR when i want, it's just the Taco is usless during winter in the snow cause all it does is spin and im not happy the only thing i can put money into the truck is the Stero and suspension
  11. May 11, 2013 at 3:46 PM
    #991
    black09
    chris
    elkton Maryland
    2009 black 2wd base
    turbo the taco
  12. May 11, 2013 at 4:55 PM
    #992
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Thought about it, buti'd have to get custom rods and pistons, custom manifold, have the ECU hacked, fuleing, get it built, trans rearend custom intercooler mounts and a bunch other. And it'd take time for the engine to be built so I'd have to DD the GTR if it gets wet which i wouldnt want to do. it'd be a 5k+ project easily for a 400hp truck
  13. May 11, 2013 at 8:58 PM
    #993
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    True
    URD. Makes a supercharger kit for the 2.7
    It's not full out custom racing but will give you much more power where you need it
    But if you are concerned on winter how does having a car make it better if it's even lower to the ground?
    Just a question
  14. May 11, 2013 at 11:29 PM
    #994
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    car would be awd, either WRX or Evo, and the URD only gives 100hp. and truck spins the whole time in snow
  15. May 12, 2013 at 6:24 PM
    #995
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    it's more like $5K for around 3-350 hp. 400 hp your would be spending alot more. internals can handle though, forged rods and iron block stock is a good recipe for booooooooost.
  16. May 12, 2013 at 8:14 PM
    #996
    Kavik
    Kavik Kavik
    Texas, DFW
    Lol just for the hell of it?
  17. May 12, 2013 at 8:51 PM
    #997
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    It'd be build it right the first time. 6262 turbo, custom forged rods and pistons, sleved ect
  18. May 12, 2013 at 9:52 PM
    #998
    Kavik
    Kavik Kavik
    Texas, DFW
    I would not mind seeing a 2nd gen turbo'd plus I wanna see it on a 2.7l.
  19. May 12, 2013 at 10:17 PM
    #999
    pinktaco808
    pinktaco808 Hot Steppa
    where did you get that from Ryan?
  20. May 12, 2013 at 11:12 PM
    #1000
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Ol skool look sorta i like it matched on a slammed mini!
    x2!!
    i wouldn't mine being boosted one day
    slammed & boosted justs sounds so nice:D
