Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Jul 5, 2013 at 12:00 PM
    #1201
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Post it up when you get it in:) if all is well I might be purchasing it as well to hopefully keep me from bottoming without raising me
    And I already know the other brackets won't work since my shocks are chodes
  2. Jul 5, 2013 at 4:00 PM
    #1202
    black09
    black09 Well-Known Member
    chris
    elkton Maryland
    2009 black 2wd base
    4.5/ 5.5 drop color matched front bumper smoked tails frenched plate in tailgate shaved tailgate handle molded rollpan fogs suede headliner suede inserts in seats with headrests removed suede arm rest kenwood double din tv mtx 12" sub with 500 watt amp trd hood full billet grill setup
    this doesnt have anything to do with suspension but i just found a 2.7 intake on ebay for 90 dollars ive been wanting one for a long time but 300 seemed like to much for a tube and filter i couldnt pass it up has anyone bought one of these they have black and polished i opted for the polished id love to see one installed
  3. Jul 5, 2013 at 4:06 PM
    #1203
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Every aftermarket intake is worse than the stock. You can look up the dyno charts on here to see for yourself .
  4. Jul 5, 2013 at 5:06 PM
    #1204
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Anyone else's pants getting tight?
  5. Jul 5, 2013 at 6:30 PM
    #1205
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats a sick truck...and that motorcycle :drool:
  6. Jul 5, 2013 at 7:18 PM
    #1206
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    Took the RoadMaster kit off and did an "eye-ball" alignment (adjusted the toe out on each side) in preperation for a real wheel alignment tomorrow. The new RoadMaster brackets should be here Tuesday. Hopefully I'll be able to put my 19's on tomorrow after the alignment and finally unveil the big surprise! (Well, not really big, but...)
    My truck now sits much better with the 3" blocks than it did with the 4" blocks... it doesn't look like there's an invisible elephant sitting in the bed now :eek:
    Got a little freaked out as I went for a test drive. Both brake shields up front were rubbing on the rotors for some reason. My truck sounded like a rusty steam train going down the road :eek:
    At just over 1,400 miles on the odometer, the truck still smells like new inside! :D
  7. Jul 5, 2013 at 7:52 PM
    #1207
    black09
    chris
    elkton Maryland
    2009 black 2wd base
    looks great i want to see a front angled shot
  8. Jul 5, 2013 at 7:54 PM
    #1208
    black09
    chris
    elkton Maryland
    2009 black 2wd base
    i just want one for looks and sound mainly lol oh and show points
  9. Jul 5, 2013 at 8:46 PM
    #1209
    Hot Taco
    Richfield, WI
    FYI... do not waste your money on the Dupli-Color caliper paint or VHT high-temp paint for your drums. Absolute garbage. My calipers are all chipped and nicked already just from bumping them with my tires as I put them on and off (and maybe just from looking at them, who knows.) The same for the rotors... if I bump them with my wheel, the paint flakes off.
    I recommend going with an epoxy caliper paint, like G2. I used a similar product years ago and it was very tough. Looks like I'll be going that route sooner than later :mad:
  10. Jul 5, 2013 at 9:28 PM
    #1210
    Kavik
    Kavik Kavik
    Texas, DFW
    I just used rustoleum high temp and the polyurethaned over that to make it last, so far so good.
  11. Jul 6, 2013 at 6:00 AM
    #1211
    DanglingFury
    Keith
    2006 4Runner 4x4
    I need to be lower...
    How big of a job are QA1's?
  12. Jul 6, 2013 at 7:07 AM
    #1212
    Kavik
    Kavik Kavik
    Texas, DFW
    Easy unless you are me apparently lol
  13. Jul 6, 2013 at 11:18 AM
    #1213
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Supah dupah easy. I had them before my drop lol
  14. Jul 6, 2013 at 6:13 PM
    #1214
    DanglingFury
    Keith
    2006 4Runner 4x4
    I've also though about running coilovers on the back and leaving one leaf spring per side instead of a 4 link. I've seen it before, just seems a little questionable.
  15. Jul 6, 2013 at 6:16 PM
    #1215
    DanglingFury
    Keith
    2006 4Runner 4x4
    Also, is there a good write up on QA1's in the front somewhere?
  16. Jul 6, 2013 at 7:25 PM
    #1216
    Kavik
    Kavik Kavik
    Texas, DFW
    They don't exist.....YET. QA1 is working on front coilover's
  17. Jul 7, 2013 at 2:20 AM
    #1217
    DanglingFury
    Keith
    2006 4Runner 4x4
    CURSESSSSS!!!!
    It's my understanding that they kinda sorta just bolt in?
  18. Jul 8, 2013 at 12:16 AM
    #1218
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    Any idea what a used DJM front set, Beefed 4" blocks and 11" u bolts would be worth? Might return mine to stock to make it easier to sell.
  19. Jul 8, 2013 at 12:35 AM
    #1219
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    There was a DC 4x4 guy who had problems with CV angles. Let me do some digging or his build thread.
    My phone makes yours look like a 5lug
  20. Jul 8, 2013 at 12:37 AM
    #1220
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm:
    i just dont freaking get it. why are you lowering a 4x4?!
