Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Sep 25, 2013 at 7:13 PM
    #1461
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    They are completely different motors :)
  2. Sep 25, 2013 at 7:59 PM
    #1462
    Smudgey
    Smudgey Trying to save the manuals
    Jack
    Pensacola, FL
    07 Tacoma RC Manual
    Window Tint, Plastidipped grille, TonnoPro folding metal tonneau cover, marble shift knob, black frame headlights, fog lights with custom switch, OE cruise control
    Hey guys, I'm pretty new here, I am planning on eventually lowering my 2007 5-lugger. Got to pick out some nice rims first, though...
  3. Sep 25, 2013 at 8:09 PM
    #1463
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    2tr is 2nd gen spec. Variable valve timing, factory tubular header, new head design, block, and internals
    My wheels
  4. Sep 25, 2013 at 8:26 PM
    #1464
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    the POS dealership did with me. :mad: As soon as they saw I lowered it, they said my suspension warranty was out the window. :( They said they could fix it for a price but I looked at them and just smiled.
    "No worries, I got that" :D
  5. Sep 25, 2013 at 8:29 PM
    #1465
    07TacoRidah
    imo rims won't matter. what you need to find out is the drop you want and then get rims.
    Worse case scenario - you get rims, BUT want a drop that means you need to cut to have the rims/tires clear .. what do you do? willing to cut? don't want to cut? things like that nature.
    peep this thread, READ CAREFULLY.
    http://www.tacomaworld.com/forum/street-trucks/247184-comprehensive-5-lug-2nd-gen-lowering-info.html
    then go here to see what size rim/tire combo will fit
    http://www.tacomaworld.com/forum/tirecalc.php
  6. Sep 25, 2013 at 8:47 PM
    #1466
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Tire size is dspendent of tire as well
  7. Sep 25, 2013 at 8:53 PM
    #1467
    07TacoRidah
    :D true, you can find out the overall size by adding in rim diameter with tire diameter - 18" rim and 225/40/18 tires = total diameter of 25.08'' something like that.
  8. Sep 25, 2013 at 8:57 PM
    #1468
    07TacoRidah
  9. Sep 25, 2013 at 9:26 PM
    #1469
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Cheater!!!!!! Hahahahahahahahahahaha
  10. Sep 25, 2013 at 9:42 PM
    #1470
    Phil Dammit
    Your Mom
    Tempe, Arizona
    No tire manufacturers
  11. Sep 25, 2013 at 9:49 PM
    #1471
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I like the look of some nice concave wheels or a wheel with a lip whether all around or just the rear but agreed its easier to make a wheel and tire fit the drop than to make the drop fit the wheels and tires but
    What size wheel you looking to go with 18, 19, 20
    And more so you planning to keep a stock height tire or possibly go smaller or taller tire
    Stock height tire or close to it for a 18 be 225/50/18 or 245/45/18 or a lil taller 255/45/18
    19 be 225/45/19 245/40/19 or lil taller 255/40/19
    Then the pattern continues for 20s 225/40/20 245/35/20 or 255/35/20
    But also ifmu run a fatter wheel like Phil in the rear you can run 275mm wide just the series will be slightly different
  12. Sep 25, 2013 at 11:43 PM
    #1472
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    I think you told me before that's what it might be. Ok hope that's all it is and I don't have to bother with this crap already
    Oh yes dooz it!
  13. Sep 26, 2013 at 8:06 AM
    #1473
    Phil Dammit
    Your Mom
    Tempe, Arizona
    dooz it lol
  14. Sep 26, 2013 at 8:28 AM
    #1474
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To complement:
    225÷25.4= 8.858" (wide) x .40= 3.543" (half of sidewall height) x 2= 7.0866" (total sidewall height) + 20" = 27.0866" total diameter.
    255÷25.4= 10.039" x 35% = 3.51" x 2 = 7.072" + 20" = 27.072"
  15. Sep 26, 2013 at 9:00 AM
    #1475
    Phil Dammit
    Your Mom
    Tempe, Arizona
  16. Sep 26, 2013 at 9:09 AM
    #1476
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
  17. Sep 26, 2013 at 9:58 AM
    #1477
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I want that too I just want a front mount intercooler
    There kit is with a top mount because they get phat hood scoops so it's like a subi style
    Makes it useless when you like me and don't got a scoop....
    At least I believe that's how I saw it on their YouTube video
  18. Sep 26, 2013 at 10:01 AM
    #1478
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You can always plumbb to a front mount. And Gadget dropped his price s/c is only 4650 now :eek:
  19. Sep 26, 2013 at 10:07 AM
    #1479
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Yeah true I'd prolly just ask em if they be able to mock up a front mount possibly I can imagine shipping is ridiculous for it though since its international
    4650........ Hahahah ONLY!
  20. Sep 26, 2013 at 2:33 PM
    #1480
    speddmn
    speddmn Well-Known Member
    Omaha
    TACOCAT
    Basics
    Hey guys, i'm guessing the 4x4 trolls aren't hanging in here now that it's 96 pages long, does anyone have a lowered DCSB 4x4? TundraRacing kit i'm assuming...
    DCLB's kind of look a little strange to me with the kit, maybe the shortbox doesnt?
    I went through most of this thread already :/
