Lowered B.S. Thread
Discussion in 'Street Trucks' started by mjbtaco, Feb 21, 2011.
  1. Dec 17, 2013 at 11:06 AM
    #1801
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    those the noises your taco makes when backing out of that driveway?
  2. Dec 17, 2013 at 1:31 PM
    #1802
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    lol yup. Im from punaluu so i was used to it when i was young, but now i got these guns even da kanackest kanack thinks twice before banging with this guy ha ha ha ;)
  3. Dec 17, 2013 at 2:16 PM
    #1803
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Hahaha funny guy ah
    Ho brah
    #I #SKED hahah
  4. Dec 18, 2013 at 7:46 AM
    #1804
    Phil Dammit
    Your Mom
    Tempe, Arizona
  5. Dec 18, 2013 at 7:48 AM
    #1805
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Called it! $850 for group buy price. $950 regular.
    So much for "savings". ;)
  6. Dec 18, 2013 at 9:00 AM
    #1806
    Phil Dammit
    Your Mom
    Tempe, Arizona
    They have already released a set for your 1st gen.
  7. Dec 18, 2013 at 9:17 AM
    #1807
    Phil Dammit
    Your Mom
    Tempe, Arizona
    How did you not know this?!?!?!?!?!?!?!?!
    EDIT: Check summit racing, they should supply them.
  8. Dec 19, 2013 at 6:44 AM
    #1808
    Phil Dammit
    Your Mom
    Tempe, Arizona
    PM me your number, my buddys build thread on customtacos will tell you everything. Have to get the setup for camaros with a different spring.
  9. Dec 28, 2013 at 12:41 AM
    #1809
    jmarquez808
    Jess
    Hawaii
    Outta curiosity what psi you guys running in your tires? I'm at 45 psi max supposed to be 52 max for these stock xrunners rims wrapped with Dunlop direzzas also ur typical stock size x runner tire.
  10. Dec 28, 2013 at 11:16 AM
    #1810
    jmarquez808
    Jess
    Hawaii
    Hey stranger! Lol wow I wonder if I'm running mine a bit high? Hm
  11. Dec 28, 2013 at 11:17 AM
    #1811
    jmarquez808
    Jess
    Hawaii
    Mine are 245/45-18 tho
  12. Dec 30, 2013 at 7:24 AM
    #1812
    Phil Dammit
    Your Mom
    Tempe, Arizona
    you most definitely are, you should be close to the manufacturer suggestions. Inside B pillar drivers side. 29ft/32rr. I run 32 all around on my 255/40/18 and 275/40/18. Go up to 35-40 for long road trips.
  13. Dec 30, 2013 at 9:20 AM
    #1813
    jmarquez808
    Jess
    Hawaii
    my bad i always do this, 255/45-18's
    so dayum i need to bring my psi down, i been running it like that for a long ass time. when im in the 30's it feels so spungy. Im gonna try 32 tho and see
  14. Dec 30, 2013 at 9:30 AM
    #1814
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You are wearing out the center of the tire faster then the edges by doing this.
  15. Jan 4, 2014 at 6:36 PM
    #1815
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Not sure if this is enough, I think I should replicate the X-runner brackets and weld them in.
  16. Jan 4, 2014 at 6:43 PM
    #1816
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Put the toyota oem lsd in the 5lug today
  17. Jan 4, 2014 at 6:44 PM
    #1817
    Kavik
    Kavik Kavik
    Texas, DFW
    The what?
  18. Jan 4, 2014 at 7:19 PM
    #1818
    Kavik
    Kavik Kavik
    Texas, DFW
    I see what he said but I don't see how that pertains to what I was talking about.
  19. Jan 4, 2014 at 7:31 PM
    #1819
    Kavik
    Kavik Kavik
    Texas, DFW
    That is what this is for.
  20. Jan 4, 2014 at 7:43 PM
    #1820
    Kavik
    Kavik Kavik
    Texas, DFW
    And that is why I have both!
