Lowered front differential on stock taco
Discussion in 'Suspension' started by Casey.Jones, Jan 15, 2021.
  1. Jan 15, 2021 at 3:29 PM
    Casey.Jones
    Casey.Jones [OP] New Member
    2018-TRD Offroad-DBL Cab-Long Bed-CMNT Gray
    None
    Just got a 2018 TRD-Offroad from a dealership. It's at the stock lift height. Took it in to get some work done and the mechanic said the truck was lifted at some point and then reversed because the front differential is lower than it should be. I plan on lifting it at some point but don't have the funds for it right now. Is it bad for the truck to leave the differential lowered or should I get it raised to stock specs until I can lift it again?
  2. Jan 15, 2021 at 5:03 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Front diff drops. On Tacomas are useless
    Casey.Jones[OP] likes this.
  3. Jan 15, 2021 at 5:08 PM
    Casey.Jones
    None
    Thank you @Dalegribble02 - Alright then I'll get it reversed. Especially if it's not needed for a lift down the road. It was like that when I puchased it so I'll have the dealership handle it. According to the mechanic it never should have been sold like this anyway.
  4. Jan 15, 2021 at 5:10 PM
    Dalegribble02
    It's take like 20 MI s to remove it. Remove skid plate then remove bolts on fro t diff pull spacers out reinstall bolts put plate back on.
    TnShooter and Casey.Jones[OP] like this.
  5. Jan 15, 2021 at 5:17 PM
    Casey.Jones
    None
    Boom. Thank you
    Dalegribble02 likes this.
