Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Nov 30, 2017 at 12:15 PM
    #2001
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Yes 6 lug prerunner.
    if you do purchase the coilovers, get the higher PPi. The shocks can only compensate so much for ride comfort. Machining will also need to be done so the coilovers can fit. Fortunately it was already done when I bought mines from another member here. Either way ride will be a little stiff/bumpy because these trucks aren’t made to be low. But I’ve felt worst rides than what I’m riding on.
    Torspd likes this.
  2. Nov 30, 2017 at 9:15 PM
    #2002
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Is this set up more comfortable than the tundra racing lower kit?
  3. Nov 30, 2017 at 9:16 PM
    #2003
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    im pretty sure thats an early 4runner hood
  4. Nov 30, 2017 at 9:25 PM
    #2004
    RedLantern
    Honolulu, Hi
    From what I hear, I believe the TR front kit will Feel closer to stock ride. @hemitruk knows since he has the TR kit with some wonderful swaybars. For me, I feel more vibebrations with my current setup.
  5. Nov 30, 2017 at 9:32 PM
    #2005
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Are x runners a 5lug v6?
  6. Nov 30, 2017 at 9:43 PM
    #2006
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Thought they were all 2.7
  7. Nov 30, 2017 at 9:52 PM
    #2007
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I believe @TRON has the TR kit already . Yea ride to me felt a little better than stock.
  8. Nov 30, 2017 at 9:53 PM
    #2008
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yup 5 lug V6 6spd manual.
    Oreo Cat[QUOTED] likes this.
  9. Dec 1, 2017 at 9:27 PM
    #2009
    TRON
    With that said... The TR kit is not comfortable compared to stock. It’s more sporty but if you hit a pothole you know it. Curious if the set you have is better than stock? Not sure what the pre runner has but the sport has blistein shocks stock.
  10. Dec 1, 2017 at 10:57 PM
    #2010
    RedLantern
    Honolulu, Hi
    My coilovers set? Hah nothing beats stock but I can hang turns pretty well. Feels like a boat thought.
  11. Dec 2, 2017 at 10:28 AM
    #2011
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just don't go as high as 750ppi springs. You'll feel every grain of sand.
    I feel the 675ppi would be best, but that would be a custom rate. 650 would be the next best compromise.
    750 is my track set. I mean DD set. :anonymous:
  12. Dec 3, 2017 at 8:17 AM
    #2012
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
  13. Dec 3, 2017 at 8:19 AM
    #2013
    Iamraiderpower
    Iamraiderpower Well-Known Member
    that truck is screaming for a 4.7 or LS swap :D
    thewarriordinghy likes this.
  14. Dec 3, 2017 at 5:11 PM
    #2014
    TRON
    So nobody has gone from the TR kit to what @RedLantern has now? Curious the differences? @hirod @hemitruk
  15. Dec 3, 2017 at 5:37 PM
    #2015
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I went from TR to non TR with a lower ride height.
    www.definedengineering.com has components for a spring under kit. As one option.
    The rear on mine is OEM shackles, Calvert Racing weld on axle perches, and QA1 shocks for the XR. On XR leaf springs.
    Front is a set of Lite Racing UCA's, strut tower adapters, Ohlins coilovers, and PAC Racing springs.
    Also took an inch out of the steering knuckles, at the top.
    BassAckwards and hemitruk like this.
  16. Dec 3, 2017 at 6:24 PM
    #2016
    RedLantern
    Honolulu, Hi
    Dang I need to get some UCA. On mines. Been procrastinating a lot lately
  17. Dec 3, 2017 at 7:10 PM
    #2017
    ButtaYoBreadd
    ButtaYoBreadd Well-Known Member
    2014 TRD OR DCSB
    Anymore pics of this? Beaut!
  18. Dec 3, 2017 at 7:49 PM
    #2018
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I wanted to do coilovers but the roads in Hawaii sucks . Plus the dollars lol. I went with a taller and little wider 285 -50-20s to kind of fill out the wheelwells. Which of coarse raised truck a little .
  19. Dec 5, 2017 at 2:03 AM
    #2019
    weazleburger
    Baton Rouge, LA
    Ls/t56 would be perfect, I've been thinking about it forever actually haha
  20. Dec 7, 2017 at 7:43 PM
    #2020
    pinktaco808
    pinktaco808 Hot Steppa
    siiik what the suspension setup and the wheel/tire combo?
