Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Mar 24, 2018 at 9:04 AM
    #2061
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Now take it to VIR! :D
  2. Mar 24, 2018 at 9:08 AM
    #2062
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    What’s vir?
  3. Mar 24, 2018 at 9:09 AM
    #2063
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Virginia International Raceway. :burnrubber:
    They are used to Xrunners.
    fatfurious2 likes this.
  4. Mar 24, 2018 at 10:45 AM
    #2064
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Way to far of a drive for me.
  5. Mar 24, 2018 at 2:02 PM
    #2065
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Pulled it out of the garage. It was 50 degrees and started snowing. Blows my mind. Hopefully can drive it soon once salt is off the roads
  6. Mar 25, 2018 at 1:53 AM
    #2066
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Core support has been replaced. I made it bolt on instead of welding it in.
    Biscuits and Torspd like this.
  7. Mar 27, 2018 at 12:16 PM
    #2067
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I rented a Dodge Charger last week for travel. I was impressed with how low the car was and still have great suspension. Hit a pothole and felt nothing.
    After installing my TR lowering kit my suspension sucks compared. I know my shocks have 95k on them and probably shot. Like to find out what’s needed to somewhat mimic that feel of the charger. Any insight greatly appreciated
  8. Mar 27, 2018 at 12:17 PM
    #2068
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Unibody is how that’s accomplished
    Bowers86 likes this.
  9. Mar 27, 2018 at 1:45 PM
    #2069
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    And an independent rear suspension.
  10. Mar 27, 2018 at 8:51 PM
    #2070
    TRON
    Unibody is a game changer! When are they going to start manufacturing unibody sport trucks?
  11. Mar 28, 2018 at 5:55 AM
    #2071
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    Not a sport truck, but this exact sentiment got me to search for lowering kits for a Honda Ridgeline, lol.
    Biscuits likes this.
  12. Mar 28, 2018 at 3:14 PM
    #2072
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Mighty Mighty Mouse and catseye like this.
  13. Mar 28, 2018 at 10:41 PM
    #2073
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Bowers86 and tinker_troy like this.
  14. Mar 28, 2018 at 11:50 PM
    #2074
    tinker_troy
    T R O Y
    WY/SD
    Bowers86 and hemitruk[QUOTED] like this.
  15. Mar 29, 2018 at 12:44 AM
    #2075
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Hemi charger pick would be awesome. Had 06 charger rt . Was a fun car .
  16. Mar 31, 2018 at 9:11 AM
    #2076
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    We actually race one of those! (well technically its a Plymouth Scamp, but it has lots of parts from a Rampage):
  17. Apr 11, 2018 at 11:39 PM
    #2077
    mjbtaco
    Michael
    Montclair , so cal
  18. Apr 11, 2018 at 11:44 PM
    #2078
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Nice!
    I could use a fresh paintjob myself. Working on a 2012 heap pf a double cab right now!
  19. Apr 11, 2018 at 11:45 PM
    #2079
    mjbtaco
    Michael
    Montclair , so cal
    man i wish my paint was fresh lol its about 15 years old and it definitely shows it haha
  20. Apr 12, 2018 at 11:48 AM
    #2080
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I have 19" SSR GT-10's going on in a couple of months.
    Biscuits and mjbtaco like this.
