Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Jul 26, 2018 at 9:54 AM
    #2161
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Never :rofl: :eek:
  2. Jul 26, 2018 at 4:21 PM
    #2162
    pinktaco808
    pinktaco808 Hot Steppa
  3. Aug 13, 2018 at 7:15 PM
    #2163
    4ondflr
    4ondflr Well-Known Member
    2002 Bagged Taco, 2013 Double Cab Daily
    Bagged, back half, sheet metal bed, custom paint, narrowed rear, 20’s
  4. Aug 14, 2018 at 11:23 AM
    #2164
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Beautiful... :cheers:
  5. Aug 16, 2018 at 10:50 PM
    #2165
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
  6. Aug 28, 2018 at 7:44 AM
    #2166
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
  7. Sep 14, 2018 at 9:24 AM
    #2167
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @hemitruk
    Do you have any idea as to what your alignment numbers are with the SOS lowering kit? I am thinking about finally installing the front portion of the kit, and am wondering if we will be looking for lower than stock caster numbers (since lifting these trucks typically calls for higher caster)..
  8. Sep 14, 2018 at 11:39 AM
    #2168
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Don't have alignment print out but everything was within specs. Did only 2 alignments so far and tires wear evenly .
    BassAckwards[QUOTED] likes this.
  9. Sep 14, 2018 at 11:57 AM
    #2169
    BassAckwards
    Sounds easy enough, thanks bud!
  10. Sep 14, 2018 at 12:02 PM
    #2170
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  11. Sep 16, 2018 at 9:08 PM
    #2171
    ToyCrawl
    ToyCrawl Active Member
    2018 OR.DBC.SB.4x4
    SCS F5 matte black 285/75/16 Nitto Ridge Grappler 5100 set to 0 with OME 887 and Icon tubular UCA front 5100 with 1” block rear Roadwire leather interior Color keyed rear bumper Side marker light tint Mirror turn signal tint Pro grill Black exhaust
    What’s up everyone! New to the forum and after seeing this thread I had to join and share my 1986 extra cab. I LOVED this truck and wish I had kept it. Not a Tacoma, but know your roots! Lol.
    Sorry for the quality of these pics, they’re from 1995. Only kid at my high school with a low rider at that time :cool:
    ireymon, pinktaco808 and Ninotaco like this.
  12. Sep 23, 2018 at 3:35 PM
    #2172
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Its finally pic worthy, with its new kicks.
  13. Sep 23, 2018 at 7:19 PM
    #2173
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hottness!!!
    arcenik likes this.
  14. Sep 30, 2018 at 9:54 PM
    #2174
    TJLILMAN
    TJLILMAN Well-Known Member
    Colorado Springs
    '08 Prerunner
    Is it possible to get the 6 lugs to sit as low as the 5 lugs? I’ve got a 6 lug (2wd) that I’d love to drop but I’m not finding anything nearly as low as the 5 lugs get.
    BassAckwards likes this.
  15. Oct 1, 2018 at 5:42 AM
    #2175
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Scroll through the previous pages. You'll find your answers.
  16. Oct 1, 2018 at 2:28 PM
    #2176
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    welp.. decided to try out the Low life..
    new daily.
    1986 22r 5 speed. Torsion drop up front, 3" block with stock leafs in the rear. new wheels are at the shop now getting polished and coated.. and will be switching to a 4" block when they are ready.
    YSZ2-jTK4Yjl--OCcEhRBw3dSsTpvbWtJKkS7Dsa_296316ad9a8e775785baf9ba83a0fcd7cea9c0d8.jpg
    zWY-353EYcUAkmxfWrTR42Go5k8I2tkNjzipEPrj_340d961530fb08bb3f0be9a047b84a3e8e69043d.jpg
    YZuQ4NB7NOxxkdU3aKJyRyfxpTjEK0Ql7EY18y2d_4b6af10bb0bc7b355ec1a6bdc12d24172bde2297.jpg
    krE_viYemHR7ga4PjB-Fh0YjcNFoU13hGiNnQXF0_dc7dc86d8a2eee7b94fb347ec91564678281be89.jpg
    -fUMNG7z1rFaLenirzGEmKFDbXRfigQ0dD9eSRuA_2ec3af4eaeaf5c5e40c201702ff2d7848b706b61.jpg
  17. Oct 1, 2018 at 2:43 PM
    #2177
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good lord that is in fantastic condition!
    BassAckwards and XPOTRPR like this.
  18. Oct 1, 2018 at 2:45 PM
    #2178
    BassAckwards
    tinker_troy and Torspd like this.
  19. Oct 1, 2018 at 2:50 PM
    #2179
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was hoping you would see it! was gonna text you some pics, but have been so busy after picking it up.
    Torspd[QUOTED] likes this.
  20. Oct 2, 2018 at 1:28 PM
    #2180
    TJLILMAN
    Colorado Springs
    '08 Prerunner
