Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Apr 7, 2019 at 12:39 PM
    #2261
    sobertrtine
    sobertrtine New Member
    Robert
    2014 Tacoma base
    First post, just picked up a 2014 base with 7k miles on it.
    Just installed the sos performance -2 inch kit on it with bilstein shocks. Then threw on some mustang gt wheels I had laying around.
  2. Apr 8, 2019 at 8:18 AM
    #2262
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    just put it on some lowering springs and lowering blocks.56157751_10155745141700882_917135874594963456_o.jpg
  3. Apr 8, 2019 at 1:20 PM
    #2263
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
  4. Apr 8, 2019 at 1:51 PM
    #2264
    pinktaco808
    pinktaco808 Hot Steppa
    Wtf that
  5. Apr 8, 2019 at 2:19 PM
    #2265
    TRON
    Custom knuckles ;)
  6. Apr 8, 2019 at 2:34 PM
    #2266
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    how much chopped out?
  7. Apr 8, 2019 at 2:34 PM
    #2267
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Got a shop to do it ? How much chopped ?
  8. Apr 8, 2019 at 3:09 PM
    #2268
    TRON
    About one inch. Yup my welder used TIG
    hemitruk likes this.
  9. Apr 8, 2019 at 4:14 PM
    #2269
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  10. Apr 9, 2019 at 4:46 PM
    #2270
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  11. Apr 11, 2019 at 9:30 AM
    #2271
    pinktaco808
    Dope
    XPOTRPR likes this.
  12. Apr 17, 2019 at 8:28 PM
    #2272
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    D63EB112-E211-4580-B6E1-9CA9F37B1DF1.jpg Gonna throw these 17” 2002 maxima wheels on my 98 ext cab and drop it 2” in rear. 5F56AA4C-108D-4C5E-8CFC-69A1E1A77CBB.jpg
  13. Apr 18, 2019 at 9:30 AM
    #2273
    pinktaco808
  14. Apr 18, 2019 at 9:53 AM
    #2274
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Just got the wheels. Gonna check them this weekend. The offset is 5mm higher and the hub bore size is 1mm off so hopefully everything checks out. Gonna give it a go this weekend and give an update
    pinktaco808 likes this.
  15. Apr 22, 2019 at 11:08 AM
    #2275
    e.deCastro
    Eric
    San Diego
    so the CB is 66.1mm?
  16. Apr 22, 2019 at 12:42 PM
    #2276
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    That’s exactly right. The hub bore on the maxima is 66.1 and Tacoma is 67.1. Think I’m just gonna run a spacer to compensate for the offset and hub bore. Maybe run a 5mm. I think they’ll look great just gonna figure something out. Didn’t put any lugs on it. Any ideas on what I can do or am I on track with the spacer idea??EB361CCB-1D51-49F6-A897-AC5454CFB9FA.jpg
    whatstcp likes this.
  17. Apr 22, 2019 at 2:42 PM
    #2277
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Decided I’m not gonna run any spacers. Just gonna try and find something that’ll bolt right up. Save and get xxrs or something. Gonna work on suspension as of now
  18. Apr 22, 2019 at 2:54 PM
    #2278
    sobertrtine
    Robert
    2014 Tacoma base
    Has anyone done anything as far as air bags in the rear of a 5-lug second gen?
    I just lowered my suspension two inches and when I'm hauling my race bike, generator, spare wheels canopy etc... there is probably an inch of clearance from the wheel to the fender.
    If anyone has any ideas for air assist or even just a little bit stiffer in the rear it would be greatly appreciated. Its currently lowered with sos performance rear blocks and the xrunner kit in the front.
  19. Apr 22, 2019 at 4:23 PM
    #2279
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you can run just hub rings instead of spacers to get them to fit the hub better.
    Ford Crown Vic wheels and Mercury Grand Marquis wheels will fit as well if you're looking for something cheap and an upgrade.
    BassAckwards likes this.
  20. Apr 22, 2019 at 4:25 PM
    #2280
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    there are Sumo Springs.. they help with additional weight and have seen them in action with great results. They might be too tall tho for a lowered application. I'm not sure..
