Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. May 25, 2019 at 6:51 PM
    #2341
    HuskerPilk
    HuskerPilk Well-Known Member
    2010 TRD SPORT PRERUNNER
    And then there's that. LOL
    pinktaco808 likes this.
  2. May 25, 2019 at 7:26 PM
    #2342
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Thank you very much!
  3. May 26, 2019 at 10:25 AM
    #2343
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    78BF445F-BD0C-4DE0-9201-8B2C46EACF97.jpg 55846218-C6D9-4A13-8623-94BE3D31FA6E.jpg
    Took these last night. Crappy iPhone camera
  4. Jun 5, 2019 at 8:19 AM
    #2344
    mjbtaco
    Michael
    Montclair , so cal
    Pics from this weekend.
  5. Jun 5, 2019 at 9:20 AM
    #2345
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    @mjbtaco that thing is looking hellaclean
    Can’t wait for mine to be there. I’ve got 2 things I gotta do before focusing on looks. I’ve got a timing chain coming up and new clutch
    mjbtaco and pinktaco808 like this.
  6. Jun 5, 2019 at 4:16 PM
    #2346
    mjbtaco
    Michael
    Montclair , so cal
    Thanks man! Any reason why you're replacing the chain? I've never had to replace one, usually just hear of the guides going out.
  7. Jun 5, 2019 at 4:19 PM
    #2347
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Just trying to do some maintenance. It has 418k miles and none of the previous owners know if it was done or not so
  8. Jun 7, 2019 at 9:22 PM
    #2348
    Spudman
    Spudman Member
    97 tacoma
    So this is what I decided to go with, Pretty lame drop but I'm looking for performance over looks.
    Can anyone suggest where to get a bushing kit, sway bars or other goods that will help with handling?
  9. Jun 7, 2019 at 9:26 PM
    #2349
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    energy suspension for the steering rack, moog blue bushings are good for the sway bar bushings.
    pinktaco808 and Spudman[QUOTED] like this.
  10. Jun 8, 2019 at 3:01 AM
    #2350
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I have helper bags on the rear of my Xrunner, I also have a 2 in drop. I used AIR LIFT 59564 kit, I didn't mount them how the directions say because I have a rear sway bar. I mounted them in front of the axle and they work great. I also have the wireless air kit so I can fill them remotely.
  11. Jun 19, 2019 at 12:48 PM
    #2351
    Fishinthe252
    Fishinthe252 Active Member
    Brett
    Currituck, NC
    07 Base
    Never really cared enough for the lifted truck look to do it to one of my vehicles but I've lowered a few in my day. The 4wd in my truck has been used maybe 3 times in the 80,000 miles I've owned it. I've looked thru about 30 pages of this thread, so far, I haven't seen a 4x4 base model lowered with the black fender flairs. I'm not sure how a lowered base would look with the black flairs, any opinions?
  12. Jun 19, 2019 at 4:33 PM
    #2352
    pinktaco808
    pinktaco808 Hot Steppa
  13. Jun 19, 2019 at 7:18 PM
    #2353
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    Did you already buy it? Summit racing has $150 rebate right now on this kit so price drops to $277!!! Curious to know your thoughts after installing because I'm looking to go this route too. I'd love QA1s but $$$
  14. Jul 2, 2019 at 10:48 AM
    #2354
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @hemitruk do you know how i could go about dropping the rear another half inch or inch if i already have the sos 3.5" drop out back? I am thinking i will need to add some hellwigs to keep it from bottoming out as it bottoms out right now sometimes
    Id like to make the truck sit level, it has some rake right now
  15. Jul 2, 2019 at 3:58 PM
    #2355
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Check with @Torspd. I think he"s using stock rear shackle with aftermarket spring perch .I got full helwig helpers and helps with bottoming out .
    Also I remember Sos made a 1in block spacer for someone onetime .Can check with them . Forgot owners name:facepalm:
    BassAckwards and pinktaco808 like this.
  16. Jul 2, 2019 at 4:00 PM
    #2356
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is correct on what my setup is. Plus the stiffer XR leaf springs, and shorted bump stops.
  17. Jul 3, 2019 at 7:01 AM
    #2357
    BassAckwards
    Thanks gents! Will do some more research!
  18. Jul 4, 2019 at 8:53 AM
    #2358
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    not mine....
  19. Jul 5, 2019 at 10:38 AM
    #2359
    pinktaco808
    Niceee
    BassAckwards likes this.
  20. Jul 8, 2019 at 6:15 AM
    #2360
    Fishinthe252
    Brett
    Currituck, NC
    07 Base
    Awesome, Troy, thank you.
    That does look pretty good....
