Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Apr 18, 2021 at 3:30 PM
    #2661
    Biggz86
    Biggz86 Member
    '15 2wd double cab
    DJM 3/4 drop kit
    Yes I used the c-notch that came with the kit but had it welded in instead of bolted.
    pinktaco808 and BananaMan like this.
  2. Apr 18, 2021 at 8:10 PM
    #2662
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    My friends Tacoma
    lowtaco94, hemitruk, joemauma and 6 others like this.
  3. Apr 18, 2021 at 8:57 PM
    #2663
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Those graphics are amazing. I'm drooling and jealous of being able to take care of that paint!
    mjbtaco[QUOTED] likes this.
  4. Apr 19, 2021 at 12:42 AM
    #2664
    Biggz86
    Biggz86 Member
    '15 2wd double cab
    DJM 3/4 drop kit
    Yups
    nightcrawler[QUOTED] likes this.
  5. Apr 25, 2021 at 12:06 PM
    #2665
    Biggz86
    Biggz86 Member
    '15 2wd double cab
    DJM 3/4 drop kit
    Just installed a gloss black "Pro" style grill from ebay o_O
  6. Apr 27, 2021 at 8:20 AM
    #2666
    pinktaco808
    pinktaco808 Hot Steppa
    Wat size rims????
  7. Apr 27, 2021 at 10:27 AM
    #2667
    BananaMan
    18x10.5 -12mm
    pinktaco808[QUOTED] likes this.
  8. Apr 30, 2021 at 6:42 PM
    #2668
    BananaMan
    If anyone was wondering how much travel you have available when sitting 6 inches low in the rear with the DJM c-notch. The front bump stop is equally close with the drop arms and Feal coilovers. About 5 inches of lowering in the front. 8B0D9429-6983-4B29-9B1A-1D1AB14D9C1C.jpg7F18E66C-CA03-4932-97E5-D0072B5CC31C.jpgC90D1DB4-6963-4626-8184-290FE9A3F380.jpg
  9. Apr 30, 2021 at 10:04 PM
    #2669
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    C-notch is looking quite healthy.
    BananaMan[QUOTED] likes this.
  10. Apr 30, 2021 at 10:08 PM
    #2670
    BananaMan
    It was installed the same day as that new frame went in, by the dealership no less. P/O had a friend there apparently.
    nightcrawler likes this.
  11. Apr 30, 2021 at 10:08 PM
    #2671
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clearly. Lol
    BananaMan likes this.
  12. Apr 30, 2021 at 10:11 PM
    #2672
    BananaMan
    When I'm swapping out the blocks I'll try and get a better pic of both sides. I'm planning on wire wheeling the loose crap off and doing a prime and paint to clean it up. Also check it over for any cracks since roads up here are rough and I'm not gentle...
    pinktaco808 likes this.
  13. Apr 30, 2021 at 10:19 PM
    #2673
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good plan.
  14. Jul 4, 2021 at 9:12 PM
    #2674
    ryoung40911
    ryoung40911 Reggie Cab Connoisseur
    Rich
    NH, USA
    Barcelona red 4x4 regular cab 2014
    OEM FJ TRD pro wheels F/R ECGS 4.88 differentials with truetrac out back Bilstein 6112/5160 shocks Icon RXTs stage 0 (3rd leaf removed from stage 1) Icon tubular Delta UCAs Durobumps with Ubolt flip kit Rear X-runner sway bar, no front bar Reinforced LCA cam tabs with locking hardware 2014 steering wheel with radio controls, lights, and cruise control Alphasucks headlights Engine splash guards I made from a template on TW Other random stuff like ac knobs and a shorty antenna
    Just got done installing my kit now I can finally post it on this thread! All 4 wheels are off of wrecked police interceptors which I think is pretty neat
  15. Jul 5, 2021 at 1:50 PM
    #2675
    ryoung40911
    Rich
    NH, USA
    Haha thanks she likes cruising with me and getting hair everywhere
  16. Jul 5, 2021 at 7:02 PM
    #2676
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    For those of you that have done the Tundra racing kit on a 4x4 or prerunner, how long did it take? Is having a helper needed?
  17. Jul 9, 2021 at 4:45 PM
    #2677
    Hambone333
    Hambone333 Member
    Trey
    02 base reg cab
    I really dig your truck. I've watched most of your videos over it. Good job brother.
  18. Jul 9, 2021 at 9:25 PM
    #2678
    mjbtaco
    Michael
    Montclair , so cal
    Thanks man, I appreciate it!
  19. Jul 10, 2021 at 11:25 AM
    #2679
    907rx7
    James
  20. Jul 15, 2021 at 8:44 AM
    #2680
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Took the 35s and new wheels for the Taco to Discount yesterday. #worktruck
