Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Jan 25, 2022 at 11:32 AM
    #2881
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Do NOT bolt in! Have them professionally welded in!! And make sure they know what they are doing…
    Makes me cringe when I see bolt in modifications to frames…
    I highly recommend some adjustable shocks I.e. QA1’s, Vikings or something similar. With the truck setting on flat ground measure the “Shock Ride Hight” there are instructions on both the mentioned shock sites. Read and Measure carefully… If you are using blocks the Shock Ride Hight should not change. Looking at the photos you posted of the rear from underneath the shocks on the truck now look close to bottoming out on themselves. Now remember I said look I can’t tell without seeing and or measuring. Someone with first Gen experience should have first hand experience & knowledge.
    Our “Reg cab” & “Access cab w/ a steel toolbox” have the same rear springs. The Access cab has 1/2 & 3/4” blocks on the rear with two different shock lengths. Our Reg cab has 1.75 & 2” rear blocks and the same rear shocks on both sides. Both trucks have the same size wheels & tires and the “Rear Ride Hight” is the same on both within a 1/16”.
    I’m changing the front coil-over mounting system on both trucks so that’s yet to be determined.
    ohcaltexscar likes this.
  2. Jan 25, 2022 at 11:53 AM
    #2882
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    Thanks again @Hayrider and @BananaMan , I didnt like the sound of bolt in c notches either!
    Anyone recommended or Tacomaworld members in SoCal able to weld in a c notch for me?
  3. Jan 25, 2022 at 2:21 PM
    #2883
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    beef welded my notch in. probably the last truck the man has ever worked on.
  4. Jan 25, 2022 at 2:41 PM
    #2884
    2Runner
    Scott
    So Cal
    Looks like the beef has not been in the world of tacomas for quite some time.. if you have a way to pm him let me know.
    Anyone else out there with some experience feel like welding me in a c notch?!
  5. Jan 25, 2022 at 2:47 PM
    #2885
    e.deCastro
    Eric
    San Diego
    sdyota in san diego can do it. beef has been out for a very long time. but he is the best. mine looks factory installed.
  6. Jan 25, 2022 at 2:55 PM
    #2886
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Another recommendation for SDYota. Went through him for my low pro bump kit front and rear.
  7. Jan 25, 2022 at 3:21 PM
    #2887
    2Runner
    Scott
    So Cal
    Thanks for the suggestions of sdyota.. is there a good way to get in touch?
    Tried to hit him on fb and the instagram..
  8. Jan 25, 2022 at 3:22 PM
    #2888
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's how I got a hold of him a couple years ago.. Instagram.
    2Runner[QUOTED] likes this.
  9. Jan 25, 2022 at 3:27 PM
    #2889
    e.deCastro
    Eric
    San Diego
    he'll get back to you. usually within a few hours.
  10. Feb 9, 2022 at 2:23 AM
    #2890
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    If you're looking for a pre-made weld in notch this is the best Tacoma specific one out there (in my opinion) .
    https://www.rohdefab.com/shop/p/9fugnf5572k7r8dv3v37g0u5hgkxz4
    But this is your frame we're talking about here so research some well known fabricators or shops in your area that will for sure get the job done correctly and more importantly, safely.
  11. Feb 9, 2022 at 7:42 AM
    #2891
    Hayrider
    Hey You…
    Convection Oven AZ
    Thanks for the info but we have two 2nd Gen’s. so I purchased these over priced POS below. I gave the blocks to whoever paid me for the shipping otherwise they would have ended up in the landfill. I then had the crappy powder coating removed. I have painted them with weldable primer so I just need to get my butt in gear and remove the stock riveted on bumpstops so they can get welded in. Then I will have to get the tailpipe remade to clear the axle movement. Does it ever end? :laughing:
    https://djmsuspension.com/product/2005-2014-toyota-tacoma-complete-3-inch-rear-lowering-kit/
  12. Feb 9, 2022 at 9:09 AM
    #2892
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm running DJM Lowering control arms on my 86 Mini. No issues with them.. and the PC is holding up well for me. Bummer it wasn't the same for you.
  13. Feb 17, 2022 at 2:36 AM
    #2893
    mjbtaco
    Michael
    Montclair , so cal
  14. Apr 1, 2022 at 12:46 PM
    #2894
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
    Put on this exhaust tip, old one was a pia to get off it was seized on there127B23F0-3BA4-45CE-9522-1D4DE2BEC27B.jpg828AEC3D-B548-48BB-8315-F34187FD2DF9.jpg
    ohcaltexscar, 907rx7 and BananaMan like this.
  15. Apr 2, 2022 at 8:51 PM
    #2895
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Looks good!
    Made me think of this scene from A Knight’s Tale :rofl:
  16. Apr 3, 2022 at 5:00 AM
    #2896
    nightcrawler
    ‘17pro
    Lol I’m gonna have to watch that
    ohcaltexscar[QUOTED] likes this.
  17. Apr 4, 2022 at 5:08 PM
    #2897
    IrunnIt
    IrunnIt Active Member
  18. Apr 4, 2022 at 5:10 PM
    #2898
    nightcrawler
    ‘17pro
    That spoiler is sweet
    tacoshell88 likes this.
  19. Apr 7, 2022 at 5:36 PM
    #2899
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    When u gonna come up to Matt’s again man.
  20. Apr 9, 2022 at 7:11 PM
    #2900
    IrunnIt
    Thank you!
