Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Feb 24, 2014 at 3:46 PM
    #1261
    JSTBCUZ
    JSTBCUZ New Member
    Nothing better than a lowered truck! :D
  2. Mar 4, 2014 at 6:37 PM
    #1262
    SlammedTaco96
    SlammedTaco96 Member
    Kyle
    Nashville
    Square G6 wheels, lowering springs/blocks.
    Here's my Taco.
  3. Mar 4, 2014 at 7:30 PM
    #1263
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :bowdown:
  4. Mar 5, 2014 at 2:00 AM
    #1264
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    586dba37adaaa0eed0dcc5a33c77cd00_zpsb2b8_99ecbf20c04cda006d7ef1d0233233afe8299c94.jpg
    ab251c50ecb25bed3ab6f35008c0a0c5_zps31bf_9fc3759b841f1cddad7a9129cfbc750fae7703bc.jpg
    3ab265863d619b96fc7f58004bcd6301_zps86c1_557f458390460e6ab21723a0eab14555cca43550.jpg
    After gym sesh haha
  5. Mar 5, 2014 at 10:48 AM
    #1265
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    This is clean:cool:
    Truck's looking good B, you needs to get them coilovers on there. Night and day brotha.
  6. Mar 5, 2014 at 11:40 AM
    #1266
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Brah tell me about it.... I do want them I think ima get some billies my kyb not doing shit but they were cheap:p
    My friend got his the other week but hasnt installed them yet. I gotta find time to take care of my UCA and lc engineering header. Just gotta decide which which is first header or new suspension
  7. Mar 5, 2014 at 11:42 AM
    #1267
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Brah, it's simple, suspension, always suspension! Speed aint good if you aint got no handling. Have you not already learned this from watching Topgear? Plus minimal hp gains for what 500 dollar?
  8. Mar 5, 2014 at 11:43 AM
    #1268
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    And i think its time for qa1 out on the rear ima just do everything proper on this b**** is the coilovers softer than the coils and billies or similar I wanna stay low but don't wanna bottom out in the fender everywhere I go or maybe I can just tub the bitch too hahah
  9. Mar 5, 2014 at 11:50 AM
    #1269
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Did you not read my post in the lowerdz BS thread? It is night and day, on the harsh quick bumps like speed bumps it is firmer, on the freeway/roads the drive is softer, and through the high speeds the truck grabs. So much so I need to get a swaybar on the rear now to stop the kick out and body roll. Not the best terminology/explanation but you get my drift. You can stay low, they have 2" of adjustment in them already. If you want to be lower then that we can do spindle spacers for you to get the rest of the drop out you want. And yeah you cheap bastard, get the Q's in the rear.
  10. Mar 5, 2014 at 12:57 PM
    #1270
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    And i think its time for qa1 out on the rear ima just do everything proper on this b**** is the coilovers softer than the coils and billies or similar I wanna stay low but don't wanna bottom out in the fender everywhere I go or maybe I can just tub too hahah
  11. Mar 5, 2014 at 1:01 PM
    #1271
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Did you not read my above post?
  12. Mar 5, 2014 at 1:01 PM
    #1272
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    I don't think I read that ha that sounds so nice:/ maybe soon ill cough up the change for it shipping to hawaii is killer though and yes I think its time for qa1 rear ill just do everything correct stiff but smooth ride and fix this stupid camber roll and possibly mini tub the front
  13. Mar 5, 2014 at 1:31 PM
    #1273
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    I got sways front and rear ;P....... But no coilovers:( I hard was it to set the adjustment. When i get them i just want those bitches to bolt up and not have to mess with it all day. If i can go 1 inch lower then the djm arms so im 4 inchs dropped up front id be stoked and leave it alone!
  14. Mar 5, 2014 at 2:51 PM
    #1274
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Gahhhh the pressure you guys put on a guy hahaha I will be doing hw on what I can afford anyone want to Pm me the link to where I can purchase the coilovers
  15. Mar 5, 2014 at 4:15 PM
    #1275
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    saw the fender in your thread about the diff noise and instantly noticed how low it was, glad you finally posted a picture, was dying to see one.
    looks clean man! awesome truck you got!
  16. Mar 5, 2014 at 7:30 PM
    #1276
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    http://twelveperformance.com/
  17. Mar 5, 2014 at 7:32 PM
    #1277
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    O shit haha I didn't know they finally put it up on their site last time I went on they didn't have it up yet thanks doe
  18. Mar 6, 2014 at 8:22 AM
    #1278
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Nice
    Indeed, what day did we agree on, sorry bro been a rough week.
    LOL, finally sold you on it
    Wheels off in and on in about 2 hours. Then a couple drives around the block and some adjustment afterwards, and then an adjustment a few weeks later once the springs settle.
  19. Mar 6, 2014 at 9:10 AM
    #1279
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Werd, I will see if I can reserve a bay now.
  20. Mar 6, 2014 at 9:36 AM
    #1280
    babelt
    babelt Well-Known Member
    Brian
    TN
    5100's all around. Front's set at 1.75" 265/75/16 Duratracs.
    Old Truck
    New Truck
    I loved my lowered taco but it just wasn't as practical around here plus it didn't meet all of my needs. I miss that thing most days though.
