Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. May 29, 2014 at 9:25 PM
    #1461
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    Has anybody done the qa1 front coil over kit from xii? Could you share your feelings on the top adapter plate? I wanna get a feel for its strength... Is it tougher than the roads in Hawaii?
  2. May 29, 2014 at 9:30 PM
    #1462
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Sorry, it's the biggest lowered thread I could find. You guys stay in the shadows
  3. May 29, 2014 at 9:35 PM
    #1463
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    www.xr-underground.com. Plenty of people running them there. Including XII.
  4. May 30, 2014 at 9:36 AM
    #1464
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Hawaii roads are fucked!!! Lol
  5. May 30, 2014 at 9:44 AM
    #1465
    jmarquez808
    Jess
    Hawaii
    Awwww shiet sorry bro! Was probably blasting sounds mobbing like us waianae guys do ha ha ha. Stop by my house next time you kruz through. Still got my number ah! Eh how's the qa1's happy with em?
  6. May 30, 2014 at 9:50 AM
    #1466
    jmarquez808
    Jess
    Hawaii
    Been wrapped up in this bike almost done. Have to sell it though :*(20140522_210420_35cf1d9a2f0519924d065e2d1c6fbb9c8952828b.jpg
  7. Jun 4, 2014 at 10:52 AM
    #1467
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Cherry I'm happy I just installed some billys up front till coilovers but gonna have the front done so i can bring it down a bit more
  8. Jun 4, 2014 at 11:06 AM
    #1468
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    First rolling shot haha
    Memorial day visit
    Photo shop FTW
  9. Jun 5, 2014 at 12:13 AM
    #1469
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Hahah these are my IG pics
  10. Jun 5, 2014 at 10:20 AM
    #1470
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
  11. Jun 11, 2014 at 4:30 AM
    #1471
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    We're doing a retrofit for it, since the owner is all of about three miles from us. Nice guy named Mike.
    In exchange for this information, anyone know of lowering kits for a pre-runner? :)
    LoboLoco337 likes this.
  12. Jun 11, 2014 at 5:00 AM
    #1472
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I do. ;) How low does he want to go? Then, how do you feel about wheel hop?
  13. Jun 11, 2014 at 5:17 AM
    #1473
    TRSAndrew
    ATL
    The question is in regards to my truck. His is going to likely have to be tube chassis to handle the power (goal is over 1500hp).
    Looks like Tundra Racing makes a decent kit for about $550 to drop mine back down to a 5-lug height.
  14. Jun 11, 2014 at 5:44 AM
    #1474
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ok. Makes sense.
    I had the Tundra Racing kit. Two things that i feel when could be better about it. 1) The block/axle perches could be a made out of a better material, as well as the plate which the U-bolts go through. That plate is also where the shock is bolted to. The sleeve where the shock is bolted to has a tendency to crack where it is welded to the plate.Even with their reinforced design. It just needs to be a higher grade steel, instead of the mild steel.
    Since you are part of a fab shop replacing with a stronger lower plate would be easy enough.
    2) With the block, it amplifies the axle wrap which is noticed at regular height. Aids in the cracking on the plate mentioned above, as well. For me, I replaced the lower plate completely with that which comes with the CalTracs traction bars. The wheel hop would actually get quite violent. With some form of traction bar, that will no longer be a problem.
    Currently, I have gone lower, out of necessity, and do not have the blocks/axle perches from Tundra racing nor their rear spring shackle. I used the OEM shackle, and a CalTrac axle perch. It makes the axle sit right on top of the leaf springs. Reduced the axle wrap more, but it greatly lowered the rear. So much so that reduced height bump stops were needed, as well as properly sized front coilovers to match the rear.
    I hope that info helps. Pick your poison. ;) If you have any more questions, I will he'll as best as I can.
  15. Jun 11, 2014 at 5:48 AM
    #1475
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shoot, didn't even notice this post. He is working on lining up some space so that he has a place to work on it. He has some mods he is tryin to get done, but again, needs a place to do them. So pretty much on hold until then. I guarantee that he is anxious to tune and turn up the boost though. :D
  16. Jun 13, 2014 at 9:10 AM
    #1476
    TRSAndrew
    ATL
    I appreciate the overview! Is there a better built kit already out there or is it best to piece-meal it together?
  17. Jun 13, 2014 at 12:14 PM
    #1477
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There are axle flip kits available from other vendors on here. Their perches are pre-welded, unlike the CalTracs. Plus it is a Tacoma specific flip kit. I believe that would be the best. But then you still need the front stuff. As in some form of a shock drop spacer, or coilovers.
    It basically depends on how you drive. If you push your vehicle, get the flip kit and some coilovers. If you just want it for looks and easy driving, get the Tundra Racing kit.
  18. Jun 19, 2014 at 1:41 PM
    #1478
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
  19. Jun 20, 2014 at 12:03 PM
    #1479
    TRSAndrew
    ATL
    Any vendors you can say specifically who to contact for it? :)
  20. Jun 20, 2014 at 1:34 PM
    #1480
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Honestly no. Have to look in the suspension thread and/or look throught the vendor section. I haven't had the necessity.
    www.definedengineering.com Might have something. Only one that I can think of. Members in the Lowered B.S. Thread might be able to help as well.
    My low. :cool:
