Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Apr 25, 2015 at 1:53 AM
    #1681
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Mocked this up
    nihonjintaco likes this.
  2. Apr 25, 2015 at 8:53 AM
    #1682
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Damn. That looks good. I already know that would be one heck of an undertaking in construction to get there. It could be done though.
  3. Apr 25, 2015 at 8:42 PM
    #1683
    hrspwr236
    hrspwr236 X-Runner Addict
    AZ
    2012 Barcelona Red X-Runner
    Python Alarm, Scangauge II, Valentine V1 w/ Blendmount, Black Front Badge, Volant CAI w/ Ram Air Scoop, TRD CBE, Doug Thorley Pipe Bomb, 19" TSW Montage, 245/45/19 Hankook V12, FLM, BHLM, 6k Heads & 3k Fogs, Undercover Tonneau Cover, Tacoma Bed Mat, Headrest Delete
    Green with envy! Nice and low!
  4. Apr 25, 2015 at 9:57 PM
    #1684
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    He had djm arms up front and xii drop springs. 4x4 leafs and blocks plus qa1s out back. I can't remember what blocks anymore 4 inch maybe more?? Seen his truck in person, verryyyy niiiiceeee. But Tacomas are a lot harder to drop and drive around Than Silverado I'd say. Ask b. Himself he sold the extended cab and bought a regular cab Silverado which is now slammed and looks sick.
  5. May 1, 2015 at 11:27 PM
    #1685
    strobe808
    strobe808 Member
    Hawaii
    prerunner trd sport debadged
  6. May 2, 2015 at 8:09 AM
    #1686
    hrspwr236
    AZ
    Looks good, how much drop?
  7. May 2, 2015 at 4:47 PM
    #1687
    strobe808
    strobe808 Member
    Hawaii
    2 in the front
    3.5 in the back
    wanted to go a little lower but theres no drop kits so i probably gotta put bags
  8. May 4, 2015 at 2:07 PM
    #1688
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    the truck looks great man, so the tundra flip kit works on the tacoma? Ive found this and the one on tundra racing but they are both for the tundra. I appriciate any help
  9. May 4, 2015 at 5:15 PM
    #1689
    hrspwr236
    AZ
    Tundra racing makes lowering kits for the Tacoma.
  10. May 4, 2015 at 7:28 PM
    #1690
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    What he said. There are tacoma drop kits. Not sure off the top of my head if there's a dedicated rear flip kit separate from the lowering kit but tom is a great guy. If it's not available online try emailing him or calling, he'll hook you up.
  11. May 4, 2015 at 8:29 PM
    #1691
    strobe808
    strobe808 Member
    Hawaii
    Yea it worked for my 2014
  12. May 12, 2015 at 10:23 PM
    #1692
    usmc.honda
    usmc.honda Member
    Okinawa, Japan
    08 PreRunner SR5
    22'' MAAS wheels (X5) SouthEastern Toyota F/Lip Billet Grille Running Boards K&N Filter AVH-P5700DVD
    Is anyone in here have a DC2 single/double cab on 18s lowered? I have a DC2 and just picked up some 18x8 +20 TE37s. Wanted to see pics of DC2 on 18s so I can get tire size idea. The DC2 has massive wheel wells and was thinking 275/40 or 265/60. I plan on dropping it a bit want it to look like a aggressive street truck with a slight drop.
  13. May 12, 2015 at 10:26 PM
    #1693
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    A rsx single or double cab?
  14. May 12, 2015 at 10:52 PM
    #1694
    usmc.honda
    usmc.honda Member
    Okinawa, Japan
    08 PreRunner SR5
    Double Cab 2nd Gen
  15. May 13, 2015 at 6:15 AM
    #1695
    hrspwr236
    AZ
    I was rocking 20x10 et20 with 275/40 with a very slight rub, with 18's you will have no problem, 20s filled the wheel well pretty good
    BassAckwards likes this.
  16. May 13, 2015 at 10:26 AM
    #1696
    hirod
    hawaii
    I have 265/60's on 18's. They're the limited wheels. I don't know how much drop I have but I do rub the top of the wheel well one in a while. Mostly in hard turns over 60mph. I can post some pics if you want later.
  17. May 15, 2015 at 2:23 PM
    #1697
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    I saw DC2 and immediately thought it was an Integra. :laugh:
  18. May 15, 2015 at 8:46 PM
    #1698
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    See I wasn't the only one
  19. May 16, 2015 at 2:13 AM
    #1699
    usmc.honda
    usmc.honda Member
    Okinawa, Japan
    08 PreRunner SR5
    Hirod can you send/ post some pics of your truck from the side? It currently has 22's on it(not chrome!) but the TE37 I want to look like a street truck just low and sleeper.
  20. May 25, 2015 at 11:05 PM
    #1700
    That Guy Corey
    That Guy Corey Yup....
    Riverside CA
    2000 Tacoma
