Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Aug 21, 2015 at 2:27 PM
    #1741
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    No if you swap to Billy's you lift back up a half inch
  2. Aug 21, 2015 at 2:38 PM
    #1742
    hacklerjason
    Ewa Beach, HI
    It's 1.7 drop on xrunners... And I'm on a base sr5 and I got a 2.25... Jives to me
  3. Aug 25, 2015 at 10:21 AM
    #1743
    hacklerjason
    Ewa Beach, HI
    You can't use those billys for the drop you need different shocks... For that height you should get something way stiff unless you want tire rub marks on your hood
  4. Aug 26, 2015 at 7:45 PM
    #1744
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    You will definitely want to take that coating off on those djm arms. Even spray paint if prepped correctly will hold up better than that. I've had a few sets of their arms and always had problems with the finish coming off. I live in NC and we only get salt on the roads maybe twice a year too.
  5. Sep 1, 2015 at 12:14 AM
    #1745
    hacklerjason
    Ewa Beach, HI
  6. Sep 7, 2015 at 4:21 AM
    #1746
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    I ran bilstien 4600 with my drop and they perform much better than stock base model one believe me. I've slammed my friends xrunners and my old taco never had problems just choose the right tire height for the job. I use to daily xii performancedrop coils with djm and bilstien 4600 4 inch been blocks 2 inch de arch xrunner leaf qa1 custom notch and rode good on 245/35/19
  7. Sep 7, 2015 at 4:45 AM
    #1747
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    The 1 weekend it was slammed
    And the daily height. I still see this bush from time to time as a work truck
  8. Sep 17, 2015 at 10:06 AM
    #1748
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    anyone here running the tundra racing kit? hows the ride?
  9. Sep 18, 2015 at 10:26 PM
    #1749
    hacklerjason
    Ewa Beach, HI
    Just put on my new wheels today.... Sold my old ones last night and on with the new ones!
    TacoPoke808 likes this.
  10. Sep 23, 2015 at 3:52 PM
    #1750
    hacklerjason
    Ewa Beach, HI
    Here are some more
    srdoublecab2.7, Bamo and Bizarroterl like this.
  11. Sep 25, 2015 at 5:30 PM
    #1751
    hacklerjason
    Ewa Beach, HI
    The front was quoted as 1.7" but actual measurement showed 2.0"... The rear is 3.0"...
  12. Sep 25, 2015 at 5:33 PM
    #1752
    hacklerjason
    Ewa Beach, HI
    If you noticed my axle doesn't look like its out of center either... With 3.0 or more drop, its evident that you need to recenter the axle to fix that look... I have seen these trucks slammed and it looks stupid if they use straight blocks and the wheel has very little gap toward the front and plenty gap rearward... 3/4" offset blocks for the mf win!
  13. Sep 25, 2015 at 6:04 PM
    #1753
    hacklerjason
    Ewa Beach, HI
    No... My blocks are both tapered AND offset... The tapered for pinion angle... and offset of axle centering... Do you notice when guys slam their trucks, the wheels have a huge gap in the rear, but very little in the front? The offset blocks resets the axle further back to center... check the pic to see what i mean
  14. Sep 25, 2015 at 7:08 PM
    #1754
    hacklerjason
    Ewa Beach, HI
    Personally, i dont care much for the djm drop arms... i have a set of the camber arms brand new, never installed... in fact those are for sale too... i elected not to go that route due to all the stories of failing welds... for me to think about failing welds while driving at freeway speeds, or even just the potholes that we have on island, im good on all that... coil springs only for the moment... stashing breads for the QA1 full coilovers for the front... in the rear im gonna keep the leaf setup but swap out to 4x4 leaf packs and stay with the qa1 18 way adjustables...
    No, my wheels are not 20's, they are 19s... the offset cost me a lot of money... i bought wheels for this damn truck twice, same wheels but different finish... the first set was 18x8.5 +30 and the fit was nice, but i wanted wider and lower offset... my second set is 19.5x9.5 +22 and its damn near perfect... ima get me some longer wheel studs and half inch spacers and be done with it
  15. Dec 12, 2015 at 8:15 AM
    #1755
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Damn dude! That is really clean! Are your suspension components a freshly powder coated set from DJM?
  16. Dec 12, 2015 at 8:17 AM
    #1756
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is a proper notch job as well. :thumbsup:
  17. Dec 12, 2015 at 8:20 AM
    #1757
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. How they keep costs down. Looks much better like this anyway.
    Of course. Far superior to the Moog brand. :thumbsup:
  18. Dec 12, 2015 at 8:20 AM
    #1758
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How do you like the ride with the coilovers?
  19. Dec 12, 2015 at 8:22 AM
    #1759
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Dec 12, 2015 at 9:26 AM
    #1760
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Increased strength there with it being fully boxed too.
