Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Jan 17, 2017 at 1:37 PM
    #1881
    slickrick614
    slickrick614 Well-Known Member
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Performance clutch, aero turbine 2525 muffler, 6k hids, 5% tints, smoked tail lights
    Here's my 06 base model 4cyl 5 lug on 18s with the Djm 3/4 drop
    Reequinata, tinker_troy and Torspd like this.
  2. Jan 17, 2017 at 7:46 PM
    #1882
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Ipicked it up from hirod when he put his back stock.
    Torspd[QUOTED] likes this.
  3. Jan 19, 2017 at 1:05 PM
    #1883
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Reequinata, Dropitmore and ch3st3an like this.
  4. Jan 20, 2017 at 12:23 AM
    #1884
    pinktaco808
    pinktaco808 Hot Steppa
    Niceee
    mjbtaco likes this.
  5. Jan 20, 2017 at 6:52 AM
    #1885
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    Sounded so good, what was the setup back then?
  6. Jan 20, 2017 at 8:43 AM
    #1886
    mjbtaco
    Michael
    Montclair , so cal
    T3/T4 ar .63 turbo 2.5" straight piped exhaust from the turbo back no muffler. Tial 38mm waste gate vented to atmosphere. Thats what that puff of dust was coming from under the truck lol
  7. Jan 21, 2017 at 4:27 PM
    #1887
    mjbtaco
    Michael
    Montclair , so cal
  8. Jan 22, 2017 at 6:40 AM
    #1888
    weazleburger
    Baton Rouge, LA
    Stock ecu?
    Sounded awesome
  9. Jan 22, 2017 at 12:44 PM
    #1889
    mjbtaco
    Michael
    Montclair , so cal
    This one was full standalone ecu. Aem ems tuned by bisimoto here in southern California
  10. Jan 25, 2017 at 10:23 AM
    #1890
    kdb310
    kdb310 Member
    Ken
    '97 SR5 Tacoma my first pick up!
    No mods yet but the plan is: - ladder rack for paddle board - bbs type 15" rims - slammed - chain steering wheel car is all original and has 148k miles, panels are clean and arguably the cleanest one I've seen for sale over the last 3 months.
    Here is my '97 taco with the djn 3/4 drop, now I'm stuck in the decision process for rims and tires. I was thinking going 15x5 or 6 in the front and 15x8 in the back with the artillary or gloss black smoothie wheels from Coker Tire, and go with the wide white wall. Thoughts?
    Any thoughts on the rim idea would be most appreciated!
    mjbtaco and Dropitmore like this.
  11. Jan 26, 2017 at 2:24 PM
    #1891
    TacoPoke808
    TacoPoke808 Well-Known Member
    Zac
    Maui, HI
    20’ Cement OR DCSB 4x4 M/T
    2/3 Drop. Sos Spacer w/ Xrunner Bilsteins & 3" Block in the rear.IMG_0776.jpg IMG_0775.jpg
    RedLantern and mjbtaco like this.
  12. Jan 26, 2017 at 6:08 PM
    #1892
    mjbtaco
    Michael
    Montclair , so cal
  13. Mar 7, 2017 at 7:36 PM
    #1893
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I'd like to lower my Prerunner, but all I find is people saying "trade for a 5-lug" However I don't wanna do that as this is my first truck and I like it quite a bit.
    The only restriction I see on the front end is the closeness of the bumpstop. The rear end seems easy, just flip the springs under the axle with a new mount. Then you could easily lower a Prerunner while not ruining its ability to be a 4x4, just install a front lift and re-flip the springs back over to the top of the axle and boom back to a prerunner. Would bump stop relocation and cut coils work for the front?
    And I've seen the Tundra racing kit but I kinda want more that 2" lower, more like 3-4" lower. (maybe more since prerunners are naturally taller than 5-lugs) I wanna run SCS F5 wheels with a street tire but that'd look super funny on stock prerunner suspension, any suggestions? (aside from buying a 5-lug or frame swapping)
    Oh yeah and spring under will help me hook better, as I lose traction up till 50 at part throttle...At Least on 10.5"W all terrains
    For reference I know nothing of lowering anything
    ChadsPride likes this.
  14. Mar 7, 2017 at 9:26 PM
    #1894
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Hardest part would be need drop spindals to correct geometry if you wanna go lower than TR kit .Check out Torspd or hirod 2nd gen build. Have not seen 1st gen lowered on here yet
  15. Mar 7, 2017 at 10:09 PM
    #1895
    Brice
    Brice Turbo Member
    Brice
    Texas
    In theory you could chop the spindle and re-weld it I guess, but is a lowered spindle necessary when you lower using coil springs? or cut springs (Ik not a good option)
  16. Mar 7, 2017 at 10:16 PM
    #1896
    T4RFTMFW
    T4RFTMFW Well-Known Member
  17. Mar 7, 2017 at 10:22 PM
    #1897
    Brice
    Brice Turbo Member
    Brice
    Texas
  18. Mar 7, 2017 at 10:24 PM
    #1898
    T4RFTMFW
    It's amazing. Would bang.
  19. Mar 7, 2017 at 11:11 PM
    #1899
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Lower u go the upper control arm get closer to inner fender well. Tie rod angle going be pretty mean.
  20. Mar 8, 2017 at 6:23 AM
    #1900
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    I wish i could make my 2013 DCLB have the same geometry of suspension as the earlier x-runner. I saw someone on here a '13 x-runner and I was almost tempted to buy it, but having a 7 year old makes the small seats tough.
    hemitruk likes this.
