Lowered Taco? LETS SEE 'EM!
Discussion in 'Street Trucks' started by chris4x4, May 4, 2012.
  1. Jun 7, 2017 at 7:37 PM
    #1961
    SLVRNBLK
    SLVRNBLK Well-Known Member
    Ozzie
    Lithia, FL
    Silver TT
  2. Jun 7, 2017 at 8:10 PM
    #1962
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Jun 11, 2017 at 9:49 PM
    #1963
    Reequinata
    Reequinata Well-Known Member
    Ree
    Torspd likes this.
  4. Jun 18, 2017 at 11:16 AM
    #1964
    Pinina
    Pinina New Member
    Tampa, Florida.
    15 2.4l manual
  5. Jun 18, 2017 at 1:41 PM
    #1965
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    Matt Farah checking out the supercharger kit:thumbsup:
  6. Jun 18, 2017 at 2:32 PM
    #1966
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I cannot remember. Did you say yours has the XII Performance coil over kit?
    What are Matt's thoughts?
  7. Jun 18, 2017 at 2:38 PM
    #1967
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Finally lowered mine. Djm control arms powder coated black with factory struts up front with xii mono leafs in rear with qa1s. Anyone have a djm cnotch for sale I need one!?
  8. Jun 19, 2017 at 10:55 AM
    #1968
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Ozzie is running the DJM 3/3 with XR Billsteins
    SLVRNBLK likes this.
  9. Jun 19, 2017 at 11:11 AM
    #1969
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's right. Thank you.
    LogCabins likes this.
  10. Jun 19, 2017 at 11:25 AM
    #1970
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    No problem
  11. Jun 20, 2017 at 1:00 PM
    #1971
    SLVRNBLK
    Ozzie
    Lithia, FL
    Silver TT
    I'm running Bilstien 4600's up front, QA1 in the rear. Matt thought the truck was cool, he's not a huge truck fan, but was really impressed for what it is. "One Take" video will be out sometime in Aug timeframe.
  12. Jun 20, 2017 at 1:05 PM
    #1972
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    "air ride rides like shit" facepalm
  13. Jun 20, 2017 at 4:25 PM
    #1973
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sweet! I am sure that it helps being more performance oriented a build. Rather than simply a lowered truck. I know he enjoyed the Syborg Truck quite a lot.
    What are your thoughts on the www.xiiperformance.com coilovers?
  14. Jun 20, 2017 at 5:24 PM
    #1974
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Those are the best your gonna get for our 5lugs......most people just don't want to fork out the $$$ but if you can or are willing to shell out the $950 I say go for it!!! If you want to go a little lower than the 2" they are gonna give you get the DJM control arms, or you can do 1" spindle spacers
  15. Jun 20, 2017 at 5:30 PM
    #1975
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Whatever you do though for the rear make sure you get QA1s and get blocks from streetacos.....make sure to get 3" tapered offset pin blocks so your wheel/axle is centered in the wheelwell and it fixes your pinion angle......with 3" blocks you will not need to notch your frame, just get low profile bumps which streetacos sells with his blocks
  16. Jun 22, 2017 at 2:07 PM
    #1976
    Raildog
    Raildog Member
  17. Jun 23, 2017 at 7:12 AM
    #1977
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No blocks on mine. Just weld on axle perches, and moved the axle to over the springs, from under.
    I did get the low profile bump stops from XII as well, as the others were regularly humping the frame.
    QA1 shocks out back for the XRunner, implemented.
    Ohlins remote reservoir coilovers up front. :D
    LogCabins[QUOTED] likes this.
  18. Jul 24, 2017 at 4:43 AM
    #1978
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
  19. Jul 27, 2017 at 8:50 AM
    #1979
    Final Lap
    Final Lap Well-Known Member
    Anaheim, CA
    Mild drop, Belltech 2/3" with ball joints flipped. One finger gap all around, alignment back to factory specs, generic Japanese wheels. ;)
  20. Jul 27, 2017 at 8:56 AM
    #1980
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    More pics and details !!!
    JimmySport likes this.
