Lowered Tacoma with lean?
Discussion in 'Street Trucks' started by Az lowtacoma, Aug 25, 2012.
  1. Aug 25, 2012 at 10:23 PM
    Az lowtacoma
    Az lowtacoma [OP] Well-Known Member
    Seth
    Arizona
    So i lowered the front of my 1995 Tacoma with belltech lowering coils after having done the back, and there is about half an inch height difference between the left and right sides. The left side being lower the right by about half an inch Is this the infamous Taco lean or is something not right?
  2. Aug 25, 2012 at 10:24 PM
    Az lowtacoma
    Seth
    Arizona
    I also used kyb monomax shocks.
  3. Aug 25, 2012 at 10:26 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    you the battery and the gas tank are on the left side so yes it does lean to the left. try measuring when you are at near empty on your tank.
  4. Aug 25, 2012 at 10:27 PM
    Az lowtacoma
    Seth
    Arizona
    Ok I will try that when it gets low agian as i just filled up recently thank you.
  5. Aug 25, 2012 at 10:27 PM
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    They all do it - it's the TACO LEAN
  6. Aug 25, 2012 at 10:30 PM
    Az lowtacoma
    Seth
    Arizona
    haha well it looks goofy on one side compared to the other especially with it being lowered and I didn't notice the lean before but oh well I guess
  7. Aug 28, 2012 at 9:07 PM
    Az lowtacoma
    Seth
    Arizona
    So the lean is starting to drive me nuts cause i swear it wasn't there before I lowered the front. Is there anything i could do to fix it aside from relocating the battery to the bed?
  8. Aug 28, 2012 at 9:10 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    I guess you could lower that side a bit more to match the lower side.
  9. Aug 28, 2012 at 9:23 PM
    Az lowtacoma
    Seth
    Arizona
    Well I thought about that, but I already bought blocks and such. The only way I could lower the front would be to cut the lowering coil right?
  10. Aug 28, 2012 at 9:32 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    ive seen people torch coils before but i wouldnt recommend it.
  11. Aug 28, 2012 at 9:35 PM
    Az lowtacoma
    Seth
    Arizona
    That sounds really terrible ha.
  12. Aug 28, 2012 at 10:14 PM
    pinktaco808
    pinktaco808 Hot Steppa
    your gonna get the gangsta bounce.
  13. Aug 28, 2012 at 10:22 PM
    Az lowtacoma
    Seth
    Arizona
  14. Aug 28, 2012 at 10:58 PM
    Az lowtacoma
    Seth
    Arizona
    So i wnet out and measured my truck again. The front is lower on the left side by half an inch and the rear left is lower by an inch. Could the shocks be different lengths and off set it like that? i didn't even think to check to make sure the rear shocks were the same length before i installed them i just assumed they were since i triple checked before i ordered them. The other thing i thought was maybe the ubolt nuts on one side had come loose compared to the other side making it off set?
  15. Aug 28, 2012 at 11:11 PM
    Az lowtacoma
    Seth
    Arizona
    So it's not the shocks cause they are the right ones i just looked again at summit and oreilly
  16. Aug 29, 2012 at 4:11 AM
    PhantomVirus
    Ron
    measure it again with a near empty tank of gas.
  17. Aug 29, 2012 at 8:47 AM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Not too sure on anything before 05+ lol.
    I know for us we can use some spacers for the front. I guess cutting the front coil just 1/2in wouldn't be TOO bad. Could be worse, right?
  18. Aug 29, 2012 at 9:01 AM
    Az lowtacoma
    Seth
    Arizona
    Yes i suppose it could be ha. I'll wait and see what happens once my gas tank is almost empty and when i change my blocks out for beefed taco blocks
  19. Aug 30, 2012 at 7:40 PM
    Az lowtacoma
    Seth
    Arizona
    Well I found a solution thanks to Brian of street tacos as to how to solve the lean
