lowering a 5lug
Discussion in '5 Lug' started by 2manyhobbies, Aug 11, 2012.
  1. Aug 11, 2012 at 12:11 PM
    2manyhobbies
    2manyhobbies [OP] Member
    Austin, TX
    2012 access cad, base + extras
    Purchased June 2012. Mods in order: Windows tinted, Code Alarm, 18" Zen wheels with 245/45/18 tires, 2/3 drop, bump stops, and K&N repacement filter. More coming soon.
    1. I've noticed most builds list the high quality drop blocks. Is there an issue with the cheaper aluminum blocks (old school universal) being used on the newer Tacos? Or is it just personal preference?
    2. Is the air bag setup only really needed if a truck is c-notched and laying on the ground? The price of the adjustable rear gas shocks are close to the complete air bag setup so it made me wonder if you could bag a truck that had a mild drop.
  2. Aug 11, 2012 at 8:39 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    avoid cheap blocks and do 4x4 leafs and defined shackles. how low you tryna go?
  3. Aug 11, 2012 at 9:07 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    imo less strain on the ubolts the better. leafs and shackles are a good start and if you want lower then do blocks. streetacos is def the place you wanna go
  4. Aug 11, 2012 at 9:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Handling the rear is simple.
    Front end is where it starts getting complicated. It's not 1980 anymore... can't just de-crank the torsion rods.
  5. Aug 15, 2012 at 7:56 AM
    2manyhobbies
    Austin, TX
    Thanks for the responses. I just finished the 2/3 drop this weekend... SittinSic drop coils in the front and blocks in the back. I was really surprised that the ride is actually smoother with the drop coils than the harsh stock coils.
    I will keep an eye out for the 4x4 leafs and improve the rear setup in the near future. I'm looking to stay around a 3" drop (total) for the rear, get the best ride possible, and prevent extra stress on the rear end. How much will the 4x4 leafs lower the rear?
  6. Aug 15, 2012 at 11:52 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Roughly 1.5 I believe
  7. Aug 15, 2012 at 12:00 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I think its somewhere around there. Then if u pull the middle leaf on the 4wd pack its 3"
  8. Aug 18, 2012 at 5:46 PM
    2manyhobbies
    Austin, TX
    All 2nd generation 4x4 leafs fit? If anybody here has gone with used/salvage 4x4 leafs how much did you pay?
  9. Aug 18, 2012 at 7:45 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    yes all 2nd gen leafs will work
