Lowering a TRD D-Cab Pre-Runner??
Discussion in 'Suspension' started by gegundez, Oct 30, 2007.
  1. Nov 23, 2007 at 9:05 PM
    gegundez
    gegundez [OP] Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    Actually just scroll to the 3rd item from the top.
  2. Nov 27, 2007 at 11:00 AM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    a block will not work to lower the back. you might want to try swapping out the leafsprings for some off of a 2wd non prerunner truck.
  3. Nov 27, 2007 at 11:20 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've been searching around and I think that I could use a block to lower the rear of my 07 PreRunner.
  4. Nov 27, 2007 at 1:06 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Guys,
    I just went out an looked. Gen 2 six lug trucks are spring over axle. A block will lift the rear end. Not drop it. The blocks will only work on 5 lug trucks.
    If the truck is too tall for your significant others, short of a major suspension re-work, just put some running boards on for her.
  5. Nov 27, 2007 at 1:49 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It's not that it is too tall to get in. I wish that I didn't feel like I was going to flip over in a tight turn. And before everyone starts, I needed a vehicle with 4 doors and a bed. I did not need a vehicle that could go offroad.
