Lowering Bilstein 5100
Discussion in 'Suspension' started by Ben96, Jun 22, 2020.
  1. Jun 22, 2020 at 6:28 AM
    Ben96
    Ben96 [OP] Well-Known Member
    2014 Tacoma Sr5
    2.5in billstein 5100’s 1in rear block
    So right now on my 4.0L taco, the Bilstein 5100s are raised all the way (~2.5 in.) and I have a 1inch rear block. For one, I don't think the block lifted the truck ! full inch, could be wrong, but anyway, the front is higher than the rear by at least 1/4 inch, which is pretty visible. And of course, things get worse when I put anything in the bed, or tow something. My question is, should I lower the lift to ~1.75 or ~.85? .85 would be easier on the 4 wheel drive stuff, wouldn't it? But I don't want rake to be too much and look silly. Thanks for your help!
  2. Jun 23, 2020 at 12:39 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    The rear block does lift the rear 1”, it is literally 1” tall. Your leafs could have sagged so it may be less than an inch now though.
    You can lower the 5100s, but the 0.85 inch perch is roughly aimed at leveling a stock truck. If you lifted the rear, then you should keep the front higher, so the 1.75” perch sounds like it’ll work for you.
