Lowering OME Dakar Leaf Springs
Discussion in 'Suspension' started by Tejas TJ, Oct 27, 2009.
  1. Oct 27, 2009 at 8:10 PM
    Tejas TJ
    Tejas TJ [OP] Active Member
    McKinney, TX
    00 Taco Prerunner SR5
    My stock leaf springs are shot on my 2000 ext. cab prerunner. So I've been looking at the OME Dakar leaf springs, but they have a 2.25" lift on them and I do not want a lifted leaf spring that much. Right now my front suspension has a 1.5" lift on it. The rear has sagged so bad I've got a 1" lift block on it to level things out. So, has anyone do removed a leaf out of an OME leaf pack to lower the rear, or do you think this would work? The description of the springs on a website I read says you can remove the second from the bottom for a more comfortable ride, but does that lower the ride height? Any help would be appreciated, thanks in advance.
  2. Oct 27, 2009 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. You can pull out a spring to lower it.
  3. Oct 27, 2009 at 9:43 PM
    Tejas TJ
    McKinney, TX
    Would you guys suggest it?
  4. Oct 28, 2009 at 6:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never done it myself, but I know a couple guys who did. They havent had problems or any issues. You loose carrying capacity, as you remove the Over load leaf.
  5. Oct 28, 2009 at 9:49 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Get a measurement and have some custom built. I know Alcans do custom rear leafs to you specifications.
  6. Oct 28, 2009 at 2:10 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I just got off the phone with both Wheeler's and TRDParts4U, and the Dakars are backordered across the globe until mid november:mad:.
    Just a heads up if you needed them soon, like I do.
    I might go with allpro, instead.
  7. Oct 28, 2009 at 7:16 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I've seen a few people on TN remove the third leaf from the top to lower the dakars. I think it was good for .5 to .75 inches.
  8. Nov 25, 2009 at 2:31 PM
    Tejas TJ
    McKinney, TX
    Well I got everything done. I put on...
    - OME 880 front coils
    - OME Comfort Struts
    - OME trim spacer
    - Toytec 3/4" lift top plates
    - OME leaf springs with the overload removed
    - OME shackle/leaf bushings
    - Toytec Proportioning valve bracket
    - OME Exhaust hanger bracket
    Everything went togather fairly easy. The leafs were very easy to replace. I made for sure to put the taller leaf spring on the driver side.
    I had recently replaced the struts on this truck with some Tokico struts from Toytec and I was able to do so with some rented strut compressors from Autozone. On the other hand you can't install new springs using these cheap strut compressor on these OME struts because they are wider in diameter. So I ended up taking them to a shop in town to have them built for $40.00.
    The truck looks good and with 2.25" of lift in the front the rear sets a good inch higher in the rear even with the overload removed, so for now I threw a couple of sacks of sack crete in the bed to break the leaf springs in faster.
    As for the ride, which is the only reason I went with these OME suspension components. I truly couldn't be happier, the ride is amazing, very smooth but very stable at the same time.
