lowering read by removing a leaf?
Discussion in 'Suspension' started by 00taco, Dec 15, 2011.
  1. Dec 15, 2011 at 5:12 PM
    00taco
    00taco [OP] Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    i was wondering if any of you guys have had experience removing one of the leafs from the leaf springs in order to drop the read like and inch or so. i dont haul alot of weight and this would level my truck easily. if so, which one would be best to pull out of the four? its on a trd 00 tacoma
  2. Dec 20, 2011 at 9:59 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    interesting......bump for you.......I have noticed that when I come across a dip in the road the front bounces but the back doesn't. This may even it out. I don't haul anything either. If you do you have to get an alignment to adjust the caster and camber back into specs.
  3. Dec 21, 2011 at 1:05 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    How many leafs do you have? 3 or 4?
    if you have 3 then maybe take the overload leaf out. if you have 4 then take the leaf that is the closest the the overload.
    however I dont advise any of this.
  4. Dec 21, 2011 at 1:08 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Pull your over load tleaf its the upside down one, it will lower it the amount of space it takes up
  5. Dec 21, 2011 at 1:25 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'd go with this. I wouldn't remove any of the leafs from the active leaf pack.
    Also, an alignment is not required afterwards. You'll only need an alignment if you're messing with the front end.
  6. Dec 21, 2011 at 10:03 PM
    brelandt
    Terry
    Dublin, CA
    Wrong.....I'm Hunter Certified and went to school for this. If the rear moves up or down the caster gets moved either positive or negative and adjustment of the lower control arm is needed to retain steerabilty.
  7. Dec 22, 2011 at 12:49 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    lol there is no control arm on the rear, its not a jeep.
  8. Dec 22, 2011 at 5:28 AM
    Pugga
    Massachusetts
    F-150 Mod
    OK... I will agree that the castor will be minorly impacted by removing or adding a leaf in the rear. That does not mean you'll need an alignment. Plenty of people put AAL's on their trucks and don't go for an alignment. Going up would be more of a concern because you'll be reducing the castor, potentially causing more of that wandering feeling. Going down (removing a leaf), you'll be increasing castor so what's the problem? Castor does not affect tire wear so unless you feel like it's not handling properly after removing or adding a leaf, getting an alignment is a waste of money. I'm not Hunter Certified :rolleyes:
  9. Dec 22, 2011 at 5:37 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    For those who would like to enhance their understanding: http://www.ozebiz.com.au/racetech/theory/align.html
  10. Dec 22, 2011 at 7:16 AM
    brelandt
    Terry
    Dublin, CA
    increase castor will cause a harsher ride and castor roll will increase which does cause wear. Also if there is a lean to one side you will have more castor on one side over the other and cause a pull.
  11. Dec 22, 2011 at 11:03 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    To add to this, if that slight of movement mattered then I would have to align my truck everytime I put a load in it?
    Also my caster is in the red and has been for about 20k miles since I went LT. My tires look fine
