lowering spare tire
Discussion in 'Toyota Trucks & SUVs' started by dunwur, Sep 1, 2013.
  1. Sep 1, 2013 at 7:48 PM
    dunwur
    dunwur [OP] Active Member
    toronto Canada
    2011 tacoma sr5 4x4
    This is driving me crazy . I tried for close to an hour to lower the spare tire from under my 2011 tacoma sr5 4x4 . The crank supplied with the jack kit doesn't seem to engage the screw to lower the wheel . What am I doing wrong ? Instructions make it sound so simple . Anyone else have this problem ?...Thanks
  2. Sep 1, 2013 at 8:00 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The thing is a pita... i'd hate to have to get to it on the side of the road at night. Like mentioned look through the hole (might even be able to see it from underneth) and look for the notch where the jack handle lines up. There's a mod on here somewhere where a member installed a section of pvc under there to help get the jack handle to the sweet spot.
    Edit- see post #1014 here... http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods-51.html#post3571643
