Lowering suggestions
Discussion in 'Street Trucks' started by kulrajg, Jul 26, 2022.
  1. Jul 26, 2022 at 9:05 AM
    kulrajg
    kulrajg [OP] Well-Known Member
    Arleta,CA
    blacked out.
    Hey everyone. I recently decided to low on my 1998 tacoma 2.4L. Trying to stay in budget I got 3/4 drop kit. Shorter Front springs and blocks on rear. The truck still isnt sitting as low as i want it to sit. Theres still almost 2 inch gap from tires to fenders. I can go low on front by replacing upper control arms with no issues. But rear leaf springs are just 2 inches higher than ground as it is. Is there any other way to lower the truck more from the back? Any input would help.
    pinktaco808 likes this.
  2. Jul 26, 2022 at 9:13 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Shackles . Thanks for squeegeeing the roads.
  3. Jul 26, 2022 at 10:27 AM
    kulrajg
    Arleta,CA
    blacked out.
    There's couple options for lift shackles but i couldn't find any lowering shackles. Do you know
    any manufacturers that makes lowering shackles specifically for these trucks or are there any other universals that would fit? Sorry kinda new to lowering stuff.
  4. Jul 26, 2022 at 10:51 AM
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    Generally speaking - any drop more than 4" you start to run into issues with bottoming out your axle to frame rails which requires a notch in the frame to overcome.
    For more drop the easy way go with larger blocks. You can look into the sdad mod on the forum here which is a oem 4x4 leaf swap. Another option, I had my leafs re-arched by a spring shop (Deaver) to give 3" drop with stock leafs.
    Or just toss a few hundred pounds of sand in the bed! Enjoy :thumbsup:
