Lowering Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ElTacoRojo_, May 4, 2021.
  1. May 6, 2021 at 1:13 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    How can you lower a 6 lug 6" that barely even has 6" wheel travel stock. Do you just set the thing on the bumpstops?
  2. May 7, 2021 at 6:18 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I have the SOS kit. It uses a strut lowering sleeve to relocate the strut springs lower on the strut. This is the opposite of how you lift them- the Bilsteins have rings that you relocate the spring upward on the shock. You HAVE to install low profile bumpstops when you use this kit because it will literally sit on the factory bumpstops. It aligns just fine, but the geometry is all out of whack and the bump steer is pretty bad. Not to mention it bottoms out on the bumpstops a lot. I even got new front springs to try to reduce the bottoming out. Overall I would definitely not do it again, because it's really only for a look. I would change mine back but I threw away the factory rear stuff when I did the flip kit.
    I really want a 5 lug, but they don't have a double cab. And I'm unwilling to do the work to swap to 5 lug frame.
  3. May 7, 2021 at 6:19 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Ya, pretty much
  4. May 7, 2021 at 7:28 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I always thought it would be neat to have a dbl. cab put on a 5 lug frame, lowered or not and thought it would be a nice looking practical DD. Never understood the whole Prerunner move just to get 4 doors. Was that a Hilux config necessity?
  5. May 11, 2021 at 11:37 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Weird flex, but ok.
    JK I'm actually pretty jelly. Did you stretch an ecab frame?
  6. May 11, 2021 at 12:12 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Same size just different mounts.
    cruxofthebisquit likes this.
  7. May 11, 2021 at 12:52 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Was the eCab you got the frame from also a V6? I know they put a V6 in the e cabs back in like 96. Would make the swap easier. I would seriously consider doing this some day.
  8. May 11, 2021 at 1:20 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I like it a lot.
  9. May 11, 2021 at 1:25 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Finding a 6 cyl. 5 lug extended cab frame (in good shape) may take a whole lot longer than changing mounts. You're kind of looking for an S Runner.
