Lowest Weight 30-33" Wheel+Tire Combo Challenge!
Discussion in 'Wheels & Tires' started by treyus30, Jul 8, 2024.
  1. Jul 8, 2024 at 11:26 AM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It's ridiculously difficult to compare specs across the internet for all the various wheel & tire manufacturers. Wish somebody would create a crowdsourced database. In lieu of finding that, this is my quest:
    Find the lightest weight wheel and tire combos that meet the following criteria for my truck:
    - Bolt Pattern: 6x139.7
    - Wheel minimum height: 17" (to clear brakes)
    - Wheel minimum width: 7.0"
    - Wheel minimum offset: 0mm (-12 to -38 preferred)
    - Tire Height Range: 30-33"
    - Tire Width Range: 9.0-11.0" (up to 12.5" in rear)
    - Wheel budget: < $2000
    - Tire category: Street Performance or A/T (no "highway")
    - UTQG minimum: 400 A B
    - Minimum max load per tire: 2000lbs
    My research has led me thus far to looking for flow formed wheels, such as SCS. The issue with these seems to be limited selection above 17".
    For tires (source: Toyo), they really seem to be within +/-5lbs for a given height - wheel size (sidewall) does not seem to matter much, but width does.
    So far, my setup comparisons are as follows:
    When I bought the truck: OEM 15" + Toyo OC A/T IIs = 24 + 40lbs = 64lbs [the number to beat, at minimum]
    Currently: 3rd gen 17" + Kenda Klever R/Ts = 25 + 70lbs = 95lbs [really anything is an improvement from here; I would keep in garage until I'm deliberately going offroading]
    Some wheels of interest:
    - Fuel Shok 18" (-12): 28lbs
    - Vision Inferno 20" (-18): 38lbs
    - Ultra Prowler 20" (-12): 37lbs
    - FN 17" (0) = 22lbs
    - SCS F5 17" (-38) = 23lbs
    - SCS F5 17" (-10) = 22lbs
    - Modco 17" (0) = 23lbs
    Some tires of interest (all Toyo so far):
    - Proxes ST III (34-40lbs)
    - Open Country QT (35-40lbs)
    - Celcius CUV (32-39lbs)
    - Proxes Sport AS+ (fails the size & load tests but they were just released with promise of more sizes by 2025)
    Right now the winners would be:
    Fuel Shock 18" + Toyo Celcius CUV P235/65R18s @ 28+32 = 60lbs (load rating barely under 2000lbs, exactly 30")
    SCS or FN 17" + Toyo Proxes ST III P275/60R17 @ 22/23+37 = 59/60lbs (exactly 30")
    So it's looking like a smaller wheel IS better since they grow in weight significantly faster than tires as wheel size increases, at least from the wheels & tires I've looked at, but I'm happy to have this challenged.
    Also interested in getting the tire weight down, if anyone has some recommendations.
    Jay__low likes this.
  2. Jul 8, 2024 at 11:56 AM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    Other wheels to consider! I have the Motegi Trail Lites come in at 24.5 lbs for as 17” wheel
    treyus30[OP] likes this.
  3. Jul 9, 2024 at 6:46 AM
    Rivermaniac
    Rivermaniac Well-Known Member
    Fn wheels , countersteer ….. other models . Maxxis xl tires 39-42 lbs . Mickey thomson xl tires 44 lbs . Method wheels , 29-30 lbs .
  4. Jul 10, 2024 at 5:23 AM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    I’m about to purchase a wheel & tire setup for my 24 4runner, I’ve lifted a few Tacoma’s over the years, so I’m somewhat well versed on the wheel and tire selections.
    Typically utilize an D or E load, probably going SL this time in a 285/70/17 Nitto Recon, it’s 48.94lbs. I have considered the 275/70/17, but they are very limited and most are E Rated.
    Tire Size . Com is a great site for time info, actual size and weights.
    Wheel wise: SCS wheels, FN Wheels or Modco wheels in 17x8(ish) with an average of 22-24 lbs.
  5. Jul 10, 2024 at 7:29 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Gram Lights 57DR-X weigh 20lbs each. Japan made and can be had for around budget.
  6. Jul 10, 2024 at 9:58 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    You'll save the most weight by finding an SL-rated tire, probably in the narrowest width possible.
    I know you said you need 17", but for reference I'm running a Toyo AT3 in a 246/75r16, SL rated, advertised weight is 37lbs. I have those mounted on 3rd gen 4runner 5-stars at around 21lbs each.
    So that's 58lbs/wheel (confirmed on the warehouse scale at work), and there's another ~3lbs that could be saved my moving to an SCS F5, if you don't mind running a wider rim (F5 is 8", recommended with for a 245 is 7").
    For your 17s, you could get the Toyo AT3 in:
    245/70r17 (30.6" advertised diameter, recommended 7" rim) SL @ 35lbs
    255/75r17 (31.1" advertised diameter, recommended 7.5" rim) SL @ 37lbs
    265/65r17 (30.6" advertised diameter, recommended 8" rim) SL @ 38lbs
    265/70r17 (31.1" advertised diameter, recommended 8" rim) SL @ 39lbs
    Of the bunch, I'd pick the 255/75. I prefer more sidewall, and think a nominal 31" (30.5"-ish actual) on a 17" rim looks proportionally awkward on a first gen.
    For some reason, Toyo's black sidewall (BSW) variants often have a lower advertised weight than the outlined wight lettering (OWL) variants. No idea how the lettering can add up to a significant weight difference, but I've seen that pattern over a few different tire sizes.
    treyus30[OP] and hemlockz like this.
  7. Aug 27, 2024 at 12:11 AM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    This thread sent me down a rabbit hole! I’m looking for 33” tires specifically, for a 4th gen, and preferably with 3 peaks mountain snowflake ratings for snowboarding, often the roads require traction tires, although can also just carry chains.
    The stock combo is around 64 lbs. wheel 27, 31” tire 37 lbs. so would be great to upgrade to a 33” for the same weight. SCS wheels are about 22 lbs, and a 285/70r17 Firestone Destination AT2/4s is just about 42 lbs. that combo would give me 33s, 3PMS, and stock weight:IMG_1084.jpg
    looks decent, also has a good warranty. My 2nd close consideration is Cooper Discoverer AT3 with black wall. Just like OP said about toyos the white letters add a couple pounds. It’s got an extra 1/8” of tread depth too compared to Firestone
    here’s all my other data for 33” SL load (P-metric) All Terrain Tires:
    Cooper Tires' Discoverer AT3 4S 65k miles
    117T 14/32nds
    42.9lbs black sidewall Manufacturer Part Number 90000046785
    44.6 lbs whitewall?
    Cooper Rugged Trek. 17/32nds
    48 lbs no 3PMS
    Firestone destination aT2 55000 warranty
    P285/70/r17 117 Tire Weight42.121
    32.8” 12/32”
    Advanta ATX 850 50,000 mile warranty
    P285/70R17. 117
    Tread Depth:13.6/32"
    Tire Weight:43 lbs
    Nexian Roadian. ATX 3-ply 44lbs. 65,000 13/32”
    Kenda Klever A/T2. 60,000 mi warranty
    117 T 13.3/32”. 44lbs.
    285/70R17 Bridgestone Dueler A/T Revo 3
    diameter of 32.8", 44 lbs 13/32”
    285/70R17 Toyo Open Country A/T III has a diameter of 32.8
    46lbs. 13.6/32”. 65k mike warranty
    Toyo open country RT. 13/32” 49lbs 45,000
    MICKEY THOMPSON BAJA BOSS A/T
    48 lb 16/32” tread depth
    General grabber APT discontinued
    14/32” 46 lbs
    BFG “non Toyota” Trail Terrain 12.5/32"
    Tire Weight:46 lbs
    BFG ko2 116Q. 15/32” 50.3 lbs
    BFG ko3 Fords. RWL 15/32” 56 lbs
    Fallken wildpeak at4
    Tread Depth:14/32"
    Tire Weight:53 lbs
    Nitto Nomad grappler 116 T
    Tread Depth:13.4/32"
    Tire Weight:46 lbs
    Lancaster LS-37/AT
    44 Lbs 118Q
  8. Aug 27, 2024 at 1:22 PM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    I've done extensive research on this.
    17" wheels that are affordable and relatively lightweight and haven't been mentioned yet:
    American Racing AR172 - 17x8 - 25.31#
    AGP 306 - 17x8 - 25#
    Black Rhino Stadium - 17x8.5 - 26#
    DX4 Beast, Caper, Rhino, Rover - 17x8.5 - 25#
    KMG Bully Ol - 17x8.5 - 24.47#
    Modco wheels - 17x8.5 - 23#
    Nomad 502DU - 17x8.5 - 23.80#
    Raceline 952B, 952BZ - 17x8.5 - 25#
    There's more but pricier
  9. Aug 27, 2024 at 2:01 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    From the package mentioned you are not going to see any significant savings from that. You could look into www.fnwheels.com and maybe save another 2-3lbs. The 16x8's Countersteer Offroad's I had were about 18lbs. However not something I would have high confidence in holding up to hard offroad use.
  10. Aug 27, 2024 at 3:24 PM
    South
    2023 TRD Ex Cab
    Picked up the SCS Stealth 6 in 17x8.5 at 22.5 lbs and am considering the Toyo Open Country RT Trail in 275/70/17 XL load at 42lbs.
    275/70R17
    Load / Speed 116T
    Weight (lbs.) 42
    Inflated Overall Diameter (in.) 32.2”
    Load ID XL
    Sidewall BSW
    Tread Depth (1/32") 13.5
    Approved Rim Width Range (in.)
    7.0-8.0-9.0
    Inflated Overall Diameter (in.) 11.0
    Max Load (lbs.) 2756
    Max Pressure (PSI) 50
  11. Aug 27, 2024 at 3:27 PM
    Rivermaniac
    Maxxis razor at 811 p285/70/17. 43 lbs
    slomoe, 5465 and backcountryj like this.
  12. Oct 1, 2024 at 6:04 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    16x8 zero offset (now FN) Konig Countersteers (17 lbs) from 2009 paired with Michelin Defender LTX 265-75-16 (40 lbs) -- total 57 lbs per wheel/tire assembly. That is 3lbs less than the factory wheels/tires as new.
    The wheels have over 250,000 miles on them from two Tacomas (2006 and 2021).
    460724214_10230012155420939_588557013378_e789dd3299607f0ec54e11bdb00bc034fd9438fc.jpg
    461102749_10230040883339119_725910187635_72317b4965c5b4478cda34b6bbe20da08c7279b1.jpg
  13. Oct 7, 2024 at 9:03 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Wow, I had assumed this thread quickly died, but quite the contrary! (TW notification fail yet again) Looks like I have a lot to review!
  14. Oct 15, 2024 at 9:10 AM
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    My current wheel / tire setup: 16x8 0 offset FN Countersteer wheels (19.5lbs) with SL 265/75/r16 Toyo AT3s (41lbs).
    Total weight = 60.5 lbs. about same weight as stock. The FN wheels shave 4 lbs off the stock trail edition rims allowing me to go up in tire size without adding additional weight.
    Fast1 and treyus30[OP] like this.
  15. Oct 15, 2024 at 10:20 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Let's spice this up for additional recommendations based on the thread responses.
    Max wheel weight: < 25lbs
    Max tire weight: 38lbs
    Max 4-pack wheel cost: $1500
    Wheel summary:
    Konig Countersteer Type-x:
    17 x 8; 6 x 139.7; -10mm; 20.9lbs;
    $1000 for 4
    SCS F5:
    17 x 8.5; 6 x 139.7; 4.30"/-10mm; 21.5 lb
    17 x 9.0; 6 x 139.7; 3.50"/-38mm; 22.5 lb
    $1,120 for 4
    Modco M71:
    17 x 8.5; 6 x 139.7; 00mm; 23.3lb
    $1,120 for 4
    Motegi MR150 TrailLite:
    17X8.5; 6X139.7; 4.75 00mm; 24.5lbs
    $920 for 4
    AGPs 306 were disqualified for having +5mm offset and no weight listed on their pages. 307s have +0mm but no weight listed but are 27lbs.
    Could not confirm the AR172s are over 25lbs, I was seeing closer to 30lbs.
    Nomads DQd for being ugly lol
    KMG Bully Ol is a contender but I don't like black wheels so those are out
    Raceline 952B Aero HD are coming in at 25lbs, so DQ'd.
    Fast1 and Polythemus like this.
  16. Oct 15, 2024 at 10:32 AM
    Roody
    Ross
    SW CT
    GX460
    My brother and I both have AR172s. He weighed all 5 of his when they came in and each was within 0.1 lbs of the claimed 25.31 lb weight.
  17. Oct 15, 2024 at 10:35 AM
    treyus30
    Trey
    Mesa / AJ, AZ
  18. Oct 15, 2024 at 10:50 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
  19. Oct 15, 2024 at 11:18 AM
    Roody
    Ross
    SW CT
    GX460
