lq9 Vortec swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shkooter, May 20, 2019.
  1. May 20, 2019 at 10:56 AM
    shkooter
    shkooter [OP] Member
    Tyler
    2005 Toyota Tacoma Prerunner
    Spyder Halos 3 Inch Lift 33 Thunderer Mud Terrains XD301 Wheels Spectre CAI
    Hey guys, I wanted to get opinions on an engine swap from the 4.0 v6 to the 6.0 lq9 in a 05 Prerunner.
    First, would it fit? I haven't seen any lq9 builds yet and was wondering if its even possible?
    Also how much work would it take? I can acquire a full lq9 without tranny for under 2k, but for a full build, how much more work and cash would it take?
    Is the lq9 worth it? or should I go with the 5.3 Vortec or maybe even the 4.8? the LS is too much money and Vortec is just an LS that needs all the fancy stuff. I want to go v8, so no 2jz or vtec Honda haha.
    Thoughts?
  2. May 20, 2019 at 11:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    No one makes a swap kit, the LS engines are small due to pushrod setup. Go with an LQ4 and build it with the money you save over the LQ9. or go with a Gen 3 or Gen 4 5.3L
    FYI toyota themselves had no problem fitting the DOHC 1UZ into a tacoma engine bay, so an LQ/LS motor would be cakewalk.
  3. May 20, 2019 at 11:28 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Why do this? Sounds like too much trouble for what it’s worth. Just buy whatever vehicle that engine if from
  4. May 20, 2019 at 3:25 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Someone on the XRunner forum swapped in a LS1 I believe.
  5. May 20, 2019 at 3:41 PM
    nd4spdbh
    SoCal
    You are telling me you wouldnt want a 400 HP N/A'd v8 tacoma that made easily 22+mpg? If i blew the motor in my truck, id entertain the idea of an LQ4 and 4L80 trans
  6. May 20, 2019 at 3:45 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    https://www.tacomaworld.com/threads/doubllds-juggernaut-ls-twin-turbo-taco.457368/
  7. May 20, 2019 at 3:45 PM
    wheeliest
    Json
    TMPE AZ
    hush
  8. May 20, 2019 at 4:55 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    But... then you'd have a Silverado... I mean, there's worse things (like a Dodge), but if you want an aluminum block, you've got a 1500 at that. Blecccccch!
    Plenty of people stabbed small blocks into old <'95 pickups, so I can't imagine an LS into a much larger engine bay is terribly difficult. Especially the most common swap fodder into the most popular non-fullsize pickup...
    I'd also look at the aluminum 5.3s, I don't imagine you'd really need the other 33 cubes. You can make tire-smoking power for a <5000lb truck out of a 5.3 too.
