LR UCA Bushings
Discussion in 'Suspension' started by Pugga, Feb 24, 2012.
  1. Mar 11, 2012 at 7:52 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    the new system for the lr (not the poly ones) are to use the 8 washers they now supply
    they should look like this a lil hard to see but washers go on both sides....
    hope u didnt double them up
    here is how it should look'
  2. Mar 11, 2012 at 7:54 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Couldn't tell ya if they were "spec ride" or not, but it looked like they had a surround nut holding them in. Not sure how to describe it, but if you took a screw driver and a hammer, you ccould unscrew the nut holding in the bushing. Now I wish I took more pics.
  3. Mar 11, 2012 at 7:55 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Ahh. So they did have a change in design between the old ones and the new polys.
  4. Mar 11, 2012 at 7:56 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    That's exactly how they looked
  5. Mar 12, 2012 at 3:09 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    The member I bought the UCA from is being AMAZING and has already ordered replacement washers and ball joint boots for me!
    Before I knew he had done that, I contacted SPC and ordered the new Spec Ride bushing kit (which comes with all needed washers:facepalm:).
    I really don't even know if I need new bushings. I just figured I might as well install the new 'hotness bushings' while I have the UCA off the rig.
    In theory, with the new bushings and new ball joint boots(with new grease packed of course), I'll basically be installing new UCA that I have a little less $ in than a new set would cost.:D
  6. Mar 29, 2012 at 10:49 AM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Next question about the LR UCAs: Are you supposed to be able to freely move the ball joint? I bought a set used and I can move it by hand, but they're tough!
    Also, can I use a penetrating oil like PB Blaster on the ball joint to try and free them up a bit?
    A little background, I bought a set used and will be rebuilding them, new boots, new bushings.
  7. Mar 29, 2012 at 10:51 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea the ball joint should move feely...not loose but free.....clean it lube it and put them on
  8. Mar 29, 2012 at 10:55 AM
    Pugga
    Massachusetts
    Thanks! Can I use PB Blaster to help clean/free up the joint? I know people use teflon lube on uniballs but I wasn't able to find that at the autoparts store near me.
    It'll be a while before they make it on the truck. I just got the new boots in the mail yesterday, new bushings are coming hopefully tomorrow.
  9. Mar 29, 2012 at 11:47 AM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    I wiped mine clean with a rag. In my case, I didn't see the need for anything else. They looked brand new after being wiped down. I wouldnt use pb blaster because it may degrade the new greese you pack back in.
  10. Mar 29, 2012 at 11:48 AM
    Pugga
    Massachusetts
    Thanks pAP. I'll just hit them with some brake cleaner, work them around a bit then pack them with new grease and hopefully they'll free up after some use.
  11. Mar 29, 2012 at 11:52 AM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Yea. The brake cleaner should evaporate quick enough to do that. The ball joints are naturally stiff. If they were loose... I'd be worried. So, don't go crazy trying to free them up.
  12. Mar 29, 2012 at 12:01 PM
    Pugga
    Massachusetts
    Thanks, that's what I was wondering. They've freed up some as I've been messing with them but when I first got them, I couldn't hold the UCA in one hand and move the ball joint in the other. The only way they'd move was if I put the UCA on the floor, stood on them and used both hands. Maybe I'm getting weak in my old age but that seemed excessive! I'll give them a light clean up, pack em with grease and call it a day. Hopefully I can get them rebuilt and on the truck soon!
  13. Mar 29, 2012 at 4:34 PM
    backcountryj
    Jonathan
    GA
    Hey Mike,
    I replaced my bushings the other day (all but one that I botched and will be swapping out as soon as the replacement arrives:().
    Used a hack saw like we discussed. Its definitely slow going and labor intensive but I didn't cut into the housing ring too much. I used a dremel with a cutting wheel to cut the outer flange of the ring you'll be trying to remove.
    Making a single cut wasn't enough to remove my outer bushing rings, so I ended up cutting a 'wedge' out. This wasn't too bad, other than having to saw two times each bushing.
    Make sure you align the new Spec Ride bushings AWAY from the vent hole when installing. Otherwise you'll be in the same boat as me, replacing a brand new (now trashed) bushing...again.
    Best of luck with the install!
  14. Mar 29, 2012 at 5:06 PM
    Pugga
    Massachusetts
    Thanks for the tip! My new bushings should arrive tomorrow :yay:
    I was able to get the ball joints freed up. I got the top piece in a vice and kept pushing at the threaded part and the more they moved the easier they got. They still take some pressure to move but I believe they're back to how a normal ball joint should act.
