LR UCA help please?
Discussion in 'Suspension' started by Scope3334, May 4, 2012.
  1. May 4, 2012 at 2:24 PM
    Scope3334
    Scope3334 [OP] Well-Known Member
    Maryland
    2012 White Tacoma TRD Sport
    Aries Bull bar, Westin Nerf bars, WeatherTech Deflectors, OEM Roof Rack
    im currently working on my truck and im installing the LR uca's. However i can not get the washers on.
    Im having problems installing the inside washer.
    currently have Bolt.Washer.UCA.Washer. Cant get bolt
  2. May 4, 2012 at 2:43 PM
    mb09
    mb09 Member
    CO
    '07 CC LB
    I just did my lr install two weeks ago...newest model with improved bushing. From your description it sounds like you are having difficulty capturing the other hole...correct me if I'm wrong.I found I had to move the arms around; up and down/in and out to catch the other bolt hole. I also made sure to lightly grease the washers where they contact the rubber bushing surface to hold them in place. Also
    As a side note and an extreme fix; my truck was hit on the driver's side last year and the body shop apparently cut the original uca bolt off and in the process slightly cut the bolt support tube (well, that is what I'll call it). This may have slightly lengthened the clamping distance - I noticed no difference in bushing pre-load after torque the uca bolt to 85 lbs. And there wasn't to much of a difference side to side in the install.Again this would be an extreme fix if all other things are correct (right part number on the uca).
  3. May 4, 2012 at 2:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you buy replacement bolts ?
  4. May 4, 2012 at 3:02 PM
    Scope3334
    Maryland
    LOL that was hard.....I got the second inside washer in just took 2 ppl it went in...whats the torque setting?
  5. May 4, 2012 at 3:06 PM
    OZ-T
    Peter North
    British Columbia
    Can't remember offhand the torque setting , but you aren't supposed to tighten it fully till the truck is on the ground and the suspension loaded
    Did you not get an installation sheet with the LR UCA's in the box ?
  6. May 4, 2012 at 3:07 PM
    mb09
    mb09 Member
    CO
    '07 CC LB
    85 lbs I believe; should find it in bjmoose's lr alignment thread. Same spec for total chaos ucas
  7. May 4, 2012 at 3:09 PM
    mb09
    mb09 Member
    CO
    '07 CC LB
    again new style bushing instruction seem to have changed the thought on torquing uca bolts whenn not on ground. there is a new instruction sheet for the new style bushings.
  8. May 4, 2012 at 3:13 PM
    OZ-T
    Peter North
    British Columbia
    Interesting
  9. May 4, 2012 at 4:44 PM
    Scope3334
    Maryland
    What do you recommend for caster setting?
  10. May 4, 2012 at 6:34 PM
    OZ-T
    Peter North
    British Columbia
