LR UCA hits springs, what about other brands?
Discussion in 'Suspension' started by Zac808, Mar 26, 2013.
  1. Mar 26, 2013 at 1:19 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    My LR's contact my springs when fully extended. It actually tore the boot. Do uniball style UCA's contact the springs?
  2. Mar 26, 2013 at 3:24 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Interesting , haven't seen this one yet
  3. Mar 26, 2013 at 3:44 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Post the suspension set up, their travel, and your alignment specifications for answers that aren't guess's.
    Pics are also worth 1,000 words.
  4. Mar 26, 2013 at 3:49 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Description says 5100s with eibachs. Thats suprising, post some pictures
  5. Mar 26, 2013 at 5:27 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    It's in my sig.
    It's actually the uniball boot that is contactinng. I'll get some pics up.
  6. Mar 27, 2013 at 12:45 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
  7. Mar 27, 2013 at 12:51 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    That bad boy is at a terrible angle, did you loosen the lower control arms when you installed? Is the SPC logo facing out?
  8. Mar 27, 2013 at 12:53 PM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Yea that's rough looking.
  9. Mar 27, 2013 at 12:59 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I torqued them once the truck was off jacks. No, I did not loosen lower control arm. SPC logo is facing out. Maybe its the 1/2" spacer. Pax side is close but not touching.
  10. Mar 27, 2013 at 1:00 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    I wonder if Eibachs are wider coils than Stock or OME?
  11. Mar 27, 2013 at 1:00 PM
    OZ-T
    Peter North
    British Columbia
    WTF
  12. Mar 27, 2013 at 1:02 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Ur lowers might be loaded up, not allowing the truck to settle.
  13. Mar 27, 2013 at 1:02 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just another grocery getter
    One or two things modded... Check out the build
    :eek: that is nowhere near what it should look like. is the ball joint mount towards the center of the slot it goes in? also how are you getting that much droop???
  14. Mar 27, 2013 at 1:04 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Keep in mind this is with the front extended on jacks.
  15. Mar 27, 2013 at 1:05 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    You don't really care, do you.
    I get the same thing with my 885's/5100's at full droop (when jacked up). It's only on the driver's side, too, where I have the 1/4" taco lean spacer. The passenger side comes close but the boot doesn't touch. I also have LR UCAs.
  16. Mar 27, 2013 at 1:08 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I was wondering if uni's touched as well. Thanks.
    Good to know. Thank You.
  17. Mar 27, 2013 at 1:14 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Thought that was on the ground.... put it down, won't be a problem unless you go on woops all the time.
  18. Mar 27, 2013 at 1:18 PM
    OZ-T
    Peter North
    British Columbia
    Is your UCA camber adjustment slid all the way inboard by any chance ?
  19. Mar 27, 2013 at 1:18 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Wow. The big top bolt on the balljoint, is it slid all the way back towards the truck?
  20. Mar 27, 2013 at 1:22 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    No, it's all the way outboard.
