LR UCA Install Help
Discussion in 'Suspension' started by bassfan, Jul 20, 2012.
  1. Jul 20, 2012 at 8:37 PM
    bassfan
    bassfan [OP] Well-Known Member
    Fort Worth
    2012 Super White Double Cab TRD Sport
    5100s Eibachs
    Well, based on the video and install guide...I didn't think this was going to be much to get these LR UCAs in. I'm comfortable working on trucks and this is my second taco...I spent 2.5 hours tonight, have one side done and called it quits til morning. I cut the bolt on the drivers side one (got passenger side done) but don't really see how I can get it out. In the picture, you can see the black lines that its hitting right before it comes out (next to the end of the bolt). I think with enough time and effort, I can probably get it out but I don't really see how I am going to get the new bolt in. May end up having to bend the fender and go the other way with it.
    Are these the gas lines that people are speaking of? Not sure because I thought the little lines that are bolted down were the gas lines. How am I supposed to get these larger black lines out of the way to get the new bolt in? The bolt head is surely not going to go around them. Is this something new on 2012s...cause I can't be the only one that has this issue if not.
    It was a giant pain in the gonads to get the big washers on the inside of the bushings when putting the new UCA in as well. I got the passenger side done, but it was with much effort. It's so tight that its quite difficult to hold the washers and UCA up there and get everything together and aligned to get the bolt through.
    Ugh...more of a project than I was hoping but I'll give it another go in the morning.
  2. Jul 21, 2012 at 6:19 AM
    Large
    Large Red
    Just bend / cut the fender outward (toward yourself) the bolt has a little 'play' in it, not much but enough to have a little wiggle room. When you have the bolt back in just use a hammer & beat the fender back to its place & you won't even notice any damage once the skirt is on.
  3. Jul 21, 2012 at 6:26 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    I took mine out the front. Remove the battery and bend the sheet metal back. If you have an extra set of hands it's a little easier. I reinstalled mine same was factory did it. Use a crecent wrench with a cloth over the metal. when you think you have it bent enough, bend a little more. I never bothered to bend mine back. With a buddy putting the bolt in you can hold the first set of washers and get the bolt through it to hold them in and then work on the other set.
  4. Jul 21, 2012 at 7:23 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Cut the bolt in half again.
  5. Jul 21, 2012 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^
  6. Jul 21, 2012 at 8:22 AM
    bassfan
    Fort Worth
    5100s Eibachs
    Ya that works to get it out but doesn't really help getting the new one in.
  7. Jul 21, 2012 at 8:26 AM
    bassfan
    Fort Worth
    5100s Eibachs
    Well I started back at 6am and had the wheels back on and tools put away by 7am this morning. I had to take a couple nuts off and move the little clip brackets in order to move those black lines just enough to get the bolt out and new one in. Pushing on the lines to the side really hard while pulling on the bolt with the other hand did the trick. It wasn't easy by any means but got it done.
    For those that bend the sheet metal to get this done...I dont see how that would have worked at all on my drivers side. The metal is directly in line with the bolt hole all the way up to where it curves back (if that makes sense). I would have had to bend it ALOT to make room for the new bolt head. Not just taking channel locks and bending it, it looked like I would have had to move a lot of metal out of the way.
  8. Jul 21, 2012 at 9:09 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Put them back in backwards
  9. Aug 31, 2012 at 1:31 PM
    NeTacoma
    NeTacoma Member
    Jameson
    Easthampton, Ma
    05 Tacoma
    OME lift kit w/spacer and AAL rear, KMC Enduro wheels, Hankook Dynapro mt tires
    New bolts in backwards
  10. Aug 31, 2012 at 9:20 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Welcome. It doesn't matter which way it goes.
  11. Aug 31, 2012 at 9:21 PM
    OZ-T
    Peter North
    British Columbia
    True
    It's just easier to put them back in backwards
  12. Aug 31, 2012 at 9:28 PM
    Anteupp
    Anteupp Mega Member
    Andrew
    South East Wisconsin
    Total Chaos Long Travel 4x4, Fox Coilovers, DMZ spring under, 16" king tripple bypasses, Garage built bedcage/bumper, full cage coming soon...
    why are you guys even cutting these bolts to begin with :frusty: take a BFH a punch and make that bolt your bitch and get it out the proper way.
  13. Aug 31, 2012 at 9:30 PM
    OZ-T
    Peter North
    British Columbia
    I didn't cut mine , don't have an aneurysm
  14. Aug 31, 2012 at 9:34 PM
    Anteupp
    Anteupp Mega Member
    Andrew
    :D
  15. Sep 1, 2012 at 2:17 PM
    NeTacoma
    NeTacoma Member
    Jameson
    Easthampton, Ma
    05 Tacoma
    Ha I did my uca's this morning, cut the old bolts out, put in the new uca's, with new bolts. Done under an hour. Or you could mess around with trying to get those bolts out...
  16. Sep 2, 2012 at 6:09 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    Is this ok? Does it make a diff? I can't see why it would, but I'm not the most mechanical guy.
  17. Sep 2, 2012 at 6:17 PM
    OZ-T
    Peter North
    British Columbia
    It doesn't matter , it's just easier to install them
  18. Sep 2, 2012 at 6:19 PM
    Gotcha88
    CA
    Yeah that's what I figured. The shop that did my lift removed the inner fender and everything, said they didn't want to just put it in backwards. Didn't know how much it mattered, cost me an extra couple hundos though.
  19. Sep 2, 2012 at 6:21 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Yeah I took a punch and a hammer and knocked em on through. Done it twice now, second time took no time at all.
  20. Sep 2, 2012 at 6:24 PM
    OZ-T
    Peter North
    British Columbia
    When we did mine we bent back the fender to remove and then reinstalled them backwards , it will be a lot easier to remove them next time if I need to
