LR UCA install question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ohbrian, Jan 24, 2012.
  1. Jan 24, 2012 at 6:26 PM
    Ohbrian
    Ohbrian [OP] Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    I was preparing to install a set of these myself this weekend. I just finished watching the install video and found out I need some kind of special tool to get the ball joints off. I have no such tool and would hate to buy one to use once. Is there any alternative method?
  2. Jan 24, 2012 at 8:48 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    LR UCA? If you mean the UCA (upper control arm) the ball joint is pressed in.
    If you mean the lower control arm, you dont need a special tool but a puller or pickle fork helps went removing the ball joint and disconnecting the tie rod end.
    I just used a pry bar and a hammer to crack the lower ball joint loose.
  3. Jan 24, 2012 at 8:50 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Pickle forks are pretty cheap btw, local parts store has them for $7.
  4. Jan 24, 2012 at 8:56 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    It's called a hammer hit the control arm right where the ball joint goes through with some force an it pops right out trust me I do it for a living. Pickle forks do work also but will 9 times out of ten mess up the boot which u don't want. If u want the pickle for go to advance auto u can rent a set an return it for nothing
  5. Jan 24, 2012 at 8:57 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    go to home depot and get a 4lb. maul. don't try without it. you will need it. trust me.
  6. Jan 24, 2012 at 9:02 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I used to do it for a living, and they dont all come out that easy. Example, my right side wouldnt move when I didnt my ball joints last week. I had to get my brother to stand on the bar (pressure on the ball joint) while I hit it as hard as I could with a hammer about 10 times before it let go.
    True about the pickle fork though, they do have a tendency to ruin the boot.
  7. Jan 24, 2012 at 9:04 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    I used a BFH on mine, and after 10 minutes of banging away it was out.
  8. Jan 24, 2012 at 10:44 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    I assume he was referring to light racing uca's.
  9. Jan 25, 2012 at 6:10 AM
    Ohbrian
    Brian
    Fremont, CA
    04 PreRunner
    OK brute force it is :) PS I dont' know if any of you have see their install video, but he uses some kind of press that looks like a C clamp. I have big hammers I'll get that fugger out.
  10. Jan 25, 2012 at 6:40 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    you'll want a ball joint press kit (available for rent at o'reilly, advanced auto, etc.) to put the new one in though... just make sure everything's lining up straight as you start to put force on the ball joint. Don't want it to start going sideways or things are liable to break!
  11. Jan 25, 2012 at 8:12 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Upper ball joints--a ball joint press
    Lower ball joints--Pitman arm puller
    You can rent them from most part stores as others have said. I wasn't so lucky with my upper ball joints. I tried for hours with a ball joint press and had no luck. I ended up tearing the front end down completely and taking the spindle assemblies to the dealership to have them press out the upper ball joints.
  12. Jan 26, 2012 at 3:36 PM
    jij0226
    jij0226 Member
    josh
    raleigh nc
    2004 tacoma base
    I installed icon uca on my 4runner 3 weeks ago. i bought the press and had trouble getting it to work. the upper ball joint kept wiggling around and the press would fall off. So i got a torch and pb blasted it for about 10-15 minutes, and beat the crap out of it. I hammered it right out.
    If you go this route make sure to remove the c clip or it wont go anywhere.
  13. Jan 27, 2012 at 1:10 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep 3 or 4 good pops on this location with a BMFH usually does the trick...
