LR UCA Install Rubbing Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Czr100, Mar 15, 2011.
  1. Mar 15, 2011 at 11:18 PM
    Czr100
    Czr100 [OP] Well-Known Member
    Cesar
    Sacramento, CA
    13 Toyota Tacoma DC LB Limited Spruce Mica 4x4
    Tanneau Cover, Tinted windows
    I just got my 3" Pro Comp lift installed. Had stock UCA for about a week and it drove fine with little to no rubbing. Tuesday I had LR UCA installed and now my rubbing is much worse than before. Here's the specs:
    Wheel specs: 275/70/r18
    and Alignment specs are
    Front left -0.2 Camber
    Front left 2.4 Caster
    Front left 0.07 Toe
    Front Right -0.2 Camber
    Front Right 2.8 Caster
    Front Right 0.05 Toe
    Any help will be much appreciated. The rubbing happens when I turn about 45 degrees and go up driveway or hit any dips. it rubs on the back body mount. Also, when in reverse, I turn the wheels to the left and reverse, the front right tire rubs? I can feel it vibrating the truck...Not fun. Not sure what to do from here. More Caster? I read somewhere that 3.3-4 Caster is less likely to rub the back body mount. Help!:confused:
  2. Mar 15, 2011 at 11:26 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    yeah, go get your caster closer to 3 and you should be fine.
  3. Mar 16, 2011 at 12:33 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I'd just trim fenders a tad. Otherwise you have to mess with the caster settings of that ball joint and it'll require a new alignment.
  4. Mar 16, 2011 at 9:29 AM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    +1...My dealership adjusted the caster when I went and had my truck aligned about 6 monsths. I knew something was wrong when I was rubbing the rear mount more. I have the LR UCA's and 285/65/18's.
  5. Mar 16, 2011 at 11:42 AM
    Czr100
    Cesar
    Sacramento, CA
    Would 3.3 Caster be too much? I am thinking that Caster at 3 might still rub. How much difference in inches is it with a +.5 caster change?
  6. Mar 16, 2011 at 11:43 AM
    Czr100
    Cesar
    Sacramento, CA
    I cut the fenders on the front already. But the rubbing is on the body mount. Metal on the back side of the inner fender.
  7. Mar 16, 2011 at 11:45 AM
    Czr100
    Cesar
    Sacramento, CA
    Do you know what your Alignment specs were after the dealership adjusted it? This way I can get a better idea of what to set it at.
  8. Mar 16, 2011 at 11:53 AM
    ETaco23
    Evan
    PNW
    I know alot of guys have there Caster at 3 or 2.8.. And they are running 285's with no issues... But they also got wheels with a 4.5" BS...
  9. Mar 16, 2011 at 12:00 PM
    RelentlessFab
    Eric
    body mount is easy enough to cut as well. :cool:
  10. Mar 16, 2011 at 12:03 PM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Germany
    2006 DCSB TRD Sport 4x4
    De badged tailgate,LED dome light,removed mud flaps,tail gate anti-theft mod,Maglite seat mount,rear diff breather,blacked out Tacoma emblems, blacked out Toyota emblem,foglight anytime,plastidiped stock rims,BHLM, behind grill light bar w/2 Hella 500FF lights, shortened 18" stock antenna, weathertec floor liners, Hi-lift, 3'' Toytec Ultimate with AAL, AVS Rainguards, Wet Okole seat covers, lowprofile tool box, pro comp 7089 w/33'' KM2s, flowmaster 40 series muffler, hidden CB mod w/firestick antenna.
    yeah just use a hand grinder and it should take care of it.
