LR UCA Installation Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Be3fTaco, Jan 3, 2013.
  1. Jan 3, 2013 at 9:57 PM
    Be3fTaco
    Be3fTaco [OP] Member
    So, I put a 3" OME lift on, but I wasn't able to get my stock UCAs off in order to put on my LR UCAs. When I tried to pull-out the bold holding the UCA in place, he head of the bolt went directly into the inside edge of the wheel well, so I would have had to remove the wheel well in order to get the bolt out. Am I missing something?
    The only idea I've had is to cut the head off the bolt and pull it through the other side of the UCA (the back side). I could then replace the bolt through the back end. Has anybody done that?
    Here are some pictures. Any help/suggestions would be appreciated.
  2. Jan 3, 2013 at 10:02 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Beat and pull the metal out of the way
  3. Jan 3, 2013 at 10:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep. Grab your biggest pair of channel locks and bend that sucker half an inch.
  4. Jan 3, 2013 at 10:04 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    :thumbsup:
  5. Jan 3, 2013 at 10:05 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This
    Be careful of lines on the inner fender
  6. Jan 4, 2013 at 6:31 AM
    roboots21
    roboots21 Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    Exactly what I did. There are a couple of electrical lines (either that or ABS lines) to be careful that you don't grab ahold of. Just keep working the bolt out and bend the wheel well as needed. Then bend it back when you get the bolt out and put the new one in from the back. Or you can cut it off as you said as well. Very simple process. Good luck!
  7. Jan 4, 2013 at 6:41 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I cut the head of the bolt off with a sawzall and then put new bolts in backwards
