LR UCAs? 3" lift? Favor please.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 92LandCruiser, Feb 17, 2012.
  1. Feb 17, 2012 at 10:28 PM
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    For those of you running LR UCAs and a full 3" lift, if you think your truck is close to level and 3" lift, would you minding taking a measurement for me?
    I need the distance from the top of the LR UCA ball joint, where the stud comes up through the jam nut on the arm, to the top of your fender well directly above it.
    Please park on a level front to back and side to side surface and tell me what you get.
    What kind of lift do you have and how level is your truck front to rear?
    Thanks guys!
  2. Feb 18, 2012 at 10:26 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  3. Feb 18, 2012 at 10:35 AM
    battleyota
    battleyota Well-Known Member
    David
    Oahu, HI
    Beast of Destruction
    OME suspension, All-Pro UCA, rear locker, 4.56 gears front and rear diffs, rear dif locker, 32x11.5 BF Goodrich Mud Terrians KM2, 15x8 Mickey Thompson classic lock, ARB bumper, K&N Air filter. Safari Snorkel.
    nice looking truck.
  4. Feb 18, 2012 at 11:27 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks man!
  5. Feb 18, 2012 at 11:27 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Toytec ultimate lift kit set exactly at 3" with new dakar leaf pack in the rear. Truck sits level. 9.25" from top of ball joint to fender well directly above.
  6. Feb 18, 2012 at 11:31 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Quick question Max , why would front to rear rake affect the UCA to fender measurement ?
  7. Feb 18, 2012 at 11:41 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    As far as the truck sitting on a level surface, this is just so weight transfer doesn't affect the measurements. As far as front to rear rake, I want measurements from people with no rake. :p
    My 886 coils are a bit uhh saggy I think. I'm running no top plate just 886s and the nitrochargers and my truck is a lot lower in the front. I can't compare measurements to the top of the flares because my flares are hacked so I figured top of the ball joint to the top of the fender well would give me a good way to compare my lift to others' lifts.
    I measured yesterday on an uneven surface side to side and front to back and got about 7 1/8 driver and 6 7/8 passenger. I'll try again in my garage today when the truck is sitting level.
    Thanks a ton Infra! I really appreciate it.
  8. Feb 18, 2012 at 11:45 AM
    OZ-T
    Peter North
    British Columbia
    Just for a point of reference , I'm at 7 1/8" with 885's , no top plate
  9. Feb 18, 2012 at 11:48 AM
    OZ-T
    Peter North
    British Columbia
    What is your centre of hub to fender measurement ?
  10. Feb 18, 2012 at 11:52 AM
    Infra
    Az
    24.75"
  11. Feb 18, 2012 at 11:52 AM
    OZ-T
    Peter North
    British Columbia
    Wow . High for a 4x4
    Thanks
  12. Feb 18, 2012 at 12:03 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  13. Feb 18, 2012 at 12:20 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thanks for the link man!
  14. Feb 18, 2012 at 4:01 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    7" driver 7 1/4" passenger for me.
  15. Feb 20, 2012 at 11:21 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  16. Feb 20, 2012 at 11:23 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Taking my idea on measuring your amount of lift I see. :popcorn: :D
  17. Feb 20, 2012 at 11:33 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  18. Feb 20, 2012 at 11:42 PM
    RelentlessFab
    Eric
    Sparks, NV
