LR UCA'S WASHERS
Discussion in 'Suspension' started by silver taco, Mar 12, 2011.
  1. Mar 12, 2011 at 9:27 PM
    silver taco
    silver taco [OP] Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    I have a question. I finished installing a 3" ome lift on my truck last weekend with LR uca's. I researched the heck out of it. I crossed my t's and dotted my i's. Except according to the directions, for the first and last washers that go on the uca bolt. The directions show the stock larger washers "backing" up the uca bushings with the smaller washers on the outside. I for some reason did the opposite. I searched this website and have found pictures where it was done both ways and the install video makes no mention of the extra washers either. I'm planning on correcting it but those bolts were a pita to remove and I am wondering what other people's opinions are on this.
  2. Mar 13, 2011 at 12:26 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    There shouldn't be any real issue with the way you did it.
    The earlier LR's didn't come with those washers. That is probably why the bushings were tearing. They claimed that it was the wrong durometer rubber that they used, but I suspected that it was the lack of movement of the inner sleeve.
    I guess the washers is there solution to allow the inner sleeve to move. Mine doesn't have the washers.
    I was working on replacing the rubber with poly bushings. Just never got around to finishing.
    Here's the thread if you're interested?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/96552-lr-uca-bushing-mod.html
    But the way you installed them should still allow the movement and should NOT be a problem.
    Makes me wonder if I should install washers? Maybe when I have the time I'll look into it?
  3. Mar 13, 2011 at 10:49 AM
    silver taco
    Los Angeles
    07 4X access cab
    I actually found you from that thread. I'm going to call SPC on Monday to see what their take is. The soonest I'll have to redo them will be next Sunday.
  4. Mar 13, 2011 at 4:23 PM
    jeepmor
    jeepmor Well-Known Member
    Stumptown
    The fat washer always goes up against the bushing to distribut the load from the side forces over a larger surface area.
    jeepmor
  5. Mar 13, 2011 at 10:02 PM
    toku58
    Mall Crawler!
    that would be true, BUT the washers are large enough to cover the surface area of the steel sleeve that runs through the bushing. So the additional size of the stock washer doesn't really do anything.
    The primary washer and the most important is the ones on the inner side of the bushing. The UCA bolt tube on the frame tower is the stationary part that the bushing need a bearing surface. The actual bolt and the UCA's can move as one unit with NO issues. The binding would occur between the stationary tube and the bushing. So the inner washer is the most important.
    Now if your main bolt wasn't lubricated and the bolt itself became frozen to the main tube? Then the outer washers would become important.
  6. Mar 14, 2011 at 9:47 PM
    silver taco
    Los Angeles
    07 4X access cab
    I called SPC this morning and talked to tech support. They said the the placement of the outside washers didn't matter. They said all that matters is that when done with the install, the uca's can freely move up and down.
  7. Mar 14, 2011 at 11:30 PM
    toku58
    Mall Crawler!
    Glad to hear you got confirmation!:thumbsup:
    I knew it wasn't an issue.
  8. Mar 15, 2011 at 4:14 PM
    silver taco
    Los Angeles
    07 4X access cab
    Yeah, I'm glad I don't have to take those bolts out again. The passenger side was fine, but I am still recovering from doing the driver's side:)
  9. Mar 16, 2011 at 7:01 PM
    jeepmor
    Stumptown
    My mistake, glad you didn't have to yard it all apart again.
  10. Oct 31, 2011 at 2:30 PM
    jdtoothnail
    jdtoothnail Member
    Joey
    Wapato, WA
    05 TRD Sport DC 4x4 w/ 3" Toytec Lift
    3" Toytec/Eibach Coilover lift w/ 5100s in front, Toytec rear BOSS shocks, Light Racing UCAs, OME Dakar Rear Leaf Packs w/ rear axle degree shims, Toyo Open Country A/T II LT285/75R16 (33"), Gear Alloy 712MB Injectors (Machined Black & Chrome wheels), Airaid Cool Air Intake System, TRD Exhaust, Black Head Light Mod, GrillCraft Black Mesh Upper & Lower Grill, Removed Mudflaps, Jensen VM9324 DVD player (secret e-brake override code on all Jensens) w/ Streaming Bluetooth Adapter, Steering Wheel Adapter & Rear Back-up Camera... ALL done by me, thanks to all the info here on TW. If I can do it, you can DEFINITELY do it!
    Thanks for the info in this thread, fellas. I recently installed the LR UCAs using the old installation instructions I printed off from the web, which means I only put on the 2 inner washers. Was curious why I had 4 washers left over, and then found the included (newer) instructions at the bottom of the box under a piece of cardboard. I'm OCD, so I may redo both.
    I got the Firestone lifetime alignment 2 weeks ago and they forgot to straighten my steering wheel. Hopefully it doesn't really have to be 6,000 miles between alignments...
    PS - does the concave side of the large factory washers face inwards (i.e. toward the bushings) or outwards? and how would that placement affect adding the SPC outer washers?
  11. Nov 1, 2011 at 7:12 AM
    silver taco
    Los Angeles
    07 4X access cab
    Ill have to check under the truck after work.
