LR UCA's- what it comes with???
Discussion in 'Suspension' started by blktaco58, Oct 18, 2012.
  1. Oct 18, 2012 at 3:27 PM
    blktaco58
    blktaco58 [OP] Well-Known Member
    Hawaii
    2012 Tacoma 4wd V6 AC
    884X springs, 1.5" AAL, 16 x 8 MT Sidebitters, 265/75/16 Duratracs, BHLM, Painted Front Valence, Wet Okoles, USA SPEC ipod,
    Im looking at buying a set of LR UCA's and was wondering what they are suppose to come with (how many washers, hardware, etc)? If you got a pic thats good to. The set Im looking at is second hand(never installed) and i want to make sure all the parts is there before I buy them....
  2. Oct 18, 2012 at 4:35 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Hold on give me a minute ill get a pic for you
  3. Oct 18, 2012 at 4:42 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    You might want a new set of oem UCA bolts also
  4. Oct 18, 2012 at 5:07 PM
    blktaco58
    Hawaii
    Do you know how much the bolts cost? Im assuming this is cuz its easier to just cut the bolt and remove correct?
    Also does it matter on the washer size? in the pic I have of the set I'm looking at, the inner holes look bigger than the ones you got posted....
  5. Oct 18, 2012 at 5:17 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    You are correct about the bolts, they are around 12 a piece at a dealership. Im not sure about the washers tho. Yours look alot smaller in overall diameter than mine.
  6. Oct 18, 2012 at 5:24 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Has the LC UCA for the 2012 changed? Your washer are definitively smaller. Did you install the metal insert into the UCA bushings yourself or did they come that way?
  7. Oct 18, 2012 at 5:26 PM
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    These L.R. UCA'S are from the latest group buy.
    1- Washers look smaller .
    2- where are the 4 bolt guide inserts .They slide inside the rubber bushings .
  8. Oct 18, 2012 at 5:26 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Those are new " Spec Ride " bushings I think
  9. Oct 18, 2012 at 5:27 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    you have the old style bushings. those washers should work for what you have.
  10. Oct 18, 2012 at 5:38 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    The guide insert seems to be in the bushing , if you zoom in you can see them. I just installed mine from the group buy and my washers are as evans much bigger.
  11. Oct 18, 2012 at 5:40 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
  12. Oct 18, 2012 at 5:55 PM
    blktaco58
    Hawaii
    So the washers in that pic are mostly likely not the correct ones? or is this a change from when they upgraded the bushings?
    Are these standard washers that any hardware store sells or is this special made stuff I have to order from toytec....
  13. Oct 18, 2012 at 5:56 PM
    OZ-T
    Peter North
    British Columbia
  14. Oct 18, 2012 at 5:56 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    When did you buy the UCA and from who?
  15. Oct 18, 2012 at 5:58 PM
    OZ-T
    Peter North
    British Columbia
    Are you asking me ?
  16. Oct 18, 2012 at 6:01 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    I would make a phone call the vendor before taking anything appart.
  17. Oct 18, 2012 at 6:02 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    No OZ-T. I know you had yours installed a while back.
  18. Oct 18, 2012 at 6:04 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    I wouls say the washers are specially made for this application.
    See Colins' comments above, you may be OK.
  19. Oct 18, 2012 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    Yes , mine are the old style
  20. Oct 18, 2012 at 6:05 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    The picture i posted has the spec ride bushings, got them from the latest group buy. Looks like you didnt need me to tell you that though.
